[geos-devel] Coordinate Sequence Dimensions?
Charlie Savage
cfis at savagexi.com
Tue Jul 11 14:20:46 EDT 2006
To create a coordinate sequence via the C API you use this method:
GEOSCoordSeq_create(unsigned int size, unsigned int dims)
If you trace through the code though, the dims is never used.
Coordinate sequences always have 3 dimensions. I guess there are plans
to have different types of coordinate sequences in the future?
In the SWIG bindings, should I hide this parameter since its not used or
go ahead and expose it (right now its exposed).
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060711/553d5bc6/smime.bin
