[geos-devel] Coordinate Sequence Dimensions?
strk at refractions.net
Tue Jul 11 17:08:21 EDT 2006
On Tue, Jul 11, 2006 at 12:20:46PM -0600, Charlie Savage wrote:
> To create a coordinate sequence via the C API you use this method:
> GEOSCoordSeq_create(unsigned int size, unsigned int dims)
> If you trace through the code though, the dims is never used.
> Coordinate sequences always have 3 dimensions. I guess there are plans
> to have different types of coordinate sequences in the future?
Maybe :)
> In the SWIG bindings, should I hide this parameter since its not used or
> go ahead and expose it (right now its exposed).
That's depend on how bindings would handled a future addition of it.
We wouldn't be able to add a parameter to a C api, thus the dimension
arg is there now.
--strk;
