[geos-devel] c api feedback
strk at refractions.net
Thu Jul 27 21:47:29 EDT 2006
On Wed, Jul 12, 2006 at 12:59:59PM -0600, Charlie Savage wrote:
> For what its worth, now that I've gone through the c api for the SWIG
> bindings, here is some feedback:
> 1. The methods GEOSCoordSeq_getSize and GEOSCoordSeq_getDimensions
> return their results by updating a pointer to a size_t parameter. Thus
> like this:
> GEOSCoordSeq_getSize(const GEOSCoordSeq s, size_t *size);
> In contrast, these methods just return the result:
> GEOSGeom_getDimensions returns value, not as a parameter
> GEOSGeom_getNumcoordinates
> GEOSGeom_getNumInteriorRings
> GEOSGeom_getNumGeometries
> Seems like an unneeded inconsistency.
Agreed. Unfortunately we really do not want to change any signature.
The rationale for returning to a parameter was to handle exceptions,
since these are inspecting-only methods it seems like
GEOSCoordSeq_getSize and GEOSCoordSeq_getDimension are the weird ones
> 2. The coordinate sequence api is extremely awkward to use. Its
> verbose and results in fairly unreadable code. Like this:
> Could we please expose a simplified for coordinate sequences in the c
> api? Such as an "add" method, and while we are at it, shouldn't there
> also be a remove method?
We're in C land, no overloads.
We might add addPoint2d(double, double) and
addPoint3d(double, double, double)
Yes, we can add remove (return 0 on exception, 1 on success).
> 3. A lot of methods, like GEOSDisjoint, return a char. The char is 0
> for false, 1 for true and 2 for an exception. I took that to mean '0',
> '1', '2'. In fact its not, its like this:
> (char)1
> Thus if you look at the char is actually '%' (or some such thing). You
> of course need to get the int result back by a typecast
> result = (int)GEOSDisjoint
> Maybe this could be better documented?
It can be probably be changed to int w/out harm to existing code...
What do other people think ?
> 4. Buffer operation now takes quadrant segments. I had no idea what
> that should be...hunting through the code it turns out to default to 8.
> Do people use the quadrant parameter much? Seems like an unneeded bit
> of complexity. At a minimum, can the default value be exposed as a
> constant? That way the SWIG bindings can set a default value for the
> buffer operation so users can just do geom.buffer(10) and can specify
> the second parameter only if needed.
Take a circle and split it by a vertical and an horizontal line.
You get 4 quadrants.
How many segments you want to end up in each quadrant when approximating
a circle ?
I suggest you define the constant internally to SWIG, if possible.
> 5. Two operations that used to be exposed via SWIG are no longer:
> within_distance
> equal_exact
We can add equal_exact (see previous mail).
We do have GEOSDistance().
> 6. Not very important, but the shape factory is not exposed via the c
> api. Not sure if anyone uses it - its used in example.cpp.
example.cpp is for C++ api, don't mess with it ! :)
> 7. The envelopes is not exposed. I find that one quite useful when
> dealing with bounding boxes - easier than having to work with a polygon
> that represents a bounding box.
That would mean defining another abstract data type, and some ops to
manage it. Not a minor tweak. I'd postpone this to when we'll have
indexes exposed (if ever :P)
> Anyway, hope these comments are helpful.
Very much, thanks!
Will you also commit the missing bits ?
--strk;
