[geos-devel] CVS GEOS union results
Howard Butler hobu at iastate.edu
Tue Jun 13 10:33:59 EDT 2006
The geometry is my own, and it is not from the JTS test suite.  Using
Python Cartographic Library with a GEOS 2.2.2 produces a result that
is more in line with the expected one (a single polygon rather than a
concatenated multipolygon).
At 04:52 PM 6/12/2006, strk at refractions.net wrote:
> >From which file from JTS did you extract the test ?
>I haven't seen the geometries visually, did you ?
>The default precision model is FLOATING (double), right,
>but for XML tests the precision model can be specified
>with the <precisionModel> tag.
>--strk;
