[geos-devel] CVS GEOS union results
    Howard Butler
    hobu at iastate.edu
    Tue Jun 13 11:36:16 EDT 2006
I am incorrect.  PCL/GEOS 2.2.2 also produces a
GEOMETRYCOLLECTION/MULTIPOLYGON.
Geometry A is a number of hexagons that were unioned
together.  Geometry B is a wedge that was created by differencing
geometry A with another (border) polygon in an attempt to "fill" to
the border.  All of these operations were done with GEOS cvs head.
At 09:33 AM 6/13/2006, Howard Butler wrote:
>The geometry is my own, and it is not from the JTS test
>suite.  Using Python Cartographic Library with a GEOS 2.2.2 produces
>a result that is more in line with the expected one (a single
>polygon rather than a concatenated multipolygon).
>At 04:52 PM 6/12/2006, strk at refractions.net wrote:
>> >From which file from JTS did you extract the test ?
>>I haven't seen the geometries visually, did you ?
>>The default precision model is FLOATING (double), right,
>>but for XML tests the precision model can be specified
>>with the <precisionModel> tag.
>>--strk;
