[geos-devel] QD (Quad-Double) Approach to Robustness
Martin Davis
mbdavis at VividSolutions.com
Wed Jun 14 14:40:00 EDT 2006
> > In any case, I'm not sure that JTS uses FP equals for
> anything other
> > than checking whether two points are *exactly* the same. So this
> > should be portable, I assume.
I think you're misreading what I said. I meant that JTS uses == (via
equals2D) to test whether the *value* of two coordinates is exactly the
same. Pointers don't enter into it.
You absolutely should NOT try to replace those equality tests with
"approximately equals". Approx equals may have a place in some of the
algorithms, but this needs to be carefully evaluated on a case-by-case
basis.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc. www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net
> [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
> strk at refractions.net
> Sent: June 14, 2006 11:36 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] QD (Quad-Double) Approach to Robustness
> On Wed, Jun 14, 2006 at 11:16:09AM -0700, Martin Davis wrote:
> > > Ok, but equality is actually used in JTS too.
> > > Does Java have an automatic approximate equality ?
> > I've been working under the assumption that Java uses a single FP
> > model, so that it's safe to compare FP numbers.
> anything other
> As far as you mean memory address comparison that would be
> portable (pointers are integer values). Unfortunately we
> don't have garbage collection for free in the C++ world, so
> in some places your identity checks might have become value
> comparisons.
> BTW, a quick grep on JTS sources for equals2D shows this is not true:
> ./algorithm/CGAlgorithms.java:197: } while
> (ring[iPrev].equals2D(hiPt) && iPrev != hiIndex);
> ./algorithm/CGAlgorithms.java:203: } while
> (ring[iNext].equals2D(hiPt) && iNext != hiIndex);
> ./algorithm/CGAlgorithms.java:214: if
> (prev.equals2D(hiPt) || next.equals2D(hiPt) || prev.equals2D(next))
> ./algorithm/LineIntersector.java:284: if
> (intPt[i].equals2D(pt)) {
> ./algorithm/LineIntersector.java:311: if (! (
> intPt[i].equals2D(inputLines[inputLineIndex][0])
> ./algorithm/LineIntersector.java:312: ||
> intPt[i].equals2D(inputLines[inputLineIndex][1]) )) {
> ./geom/Coordinate.java:134: public boolean
> equals2D(Coordinate other) {
> ./geom/Coordinate.java:159: return equals2D((Coordinate) other);
> ./geom/CoordinateList.java:141: if
> (last.equals2D(coord)) return;
> ./geom/LineString.java:146: return
> getCoordinateN(0).equals2D(getCoordinateN(getNumPoints() - 1));
> ./geomgraph/Edge.java:193: if (intPt.equals2D(nextPt)) {
> ./geomgraph/Edge.java:234: if (! pts[i].equals2D(e.pts[i])) {
> ./geomgraph/Edge.java:237: if (!
> pts[i].equals2D(e.pts[--iRev])) {
> ./geomgraph/Edge.java:253: if (! pts[i].equals2D(e.pts[i])) {
> ./geomgraph/EdgeIntersectionList.java:145: boolean
> useIntPt1 = ei1.dist > 0.0 || ! ei1.coord.equals2D(lastSegStartPt);
> ./noding/SegmentNode.java:57: isInterior = !
> coord.equals2D(segString.getCoordinate(segmentIndex));
> ./noding/SegmentNode.java:81: if
> (coord.equals2D(other.coord)) return 0;
> ./noding/SegmentNodeList.java:69:
> Assert.isTrue(ei.coord.equals2D(intPt), "Found equal nodes
> with different coordinates");
> ./noding/SegmentNodeList.java:70:// if (!
> ei.coord.equals2D(intPt))
> ./noding/SegmentNodeList.java:126: if (p0.equals2D(p2)) {
> ./noding/SegmentNodeList.java:159: if (!
> ei0.coord.equals2D(ei1.coord)) return false;
> ./noding/SegmentNodeList.java:212: if (!
> pt0.equals2D(edgePts[0]))
> ./noding/SegmentNodeList.java:218: if (!
> ptn.equals2D(edgePts[edgePts.length - 1]))
> ./noding/SegmentNodeList.java:238: boolean useIntPt1 =
> ei1.isInterior() || ! ei1.coord.equals2D(lastSegStartPt);
> ./noding/SegmentString.java:157: if
> ./noding/SegmentPointComparator.java:30: if
> (p0.equals2D(p1)) return 0;
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
