[geos-devel] QD (Quad-Double) Approach to Robustness
Mateusz Loskot mateusz at loskot.net
Wed Jun 14 14:42:15 EDT 2006
strk at refractions.net wrote:
> On Wed, Jun 14, 2006 at 11:16:09AM -0700, Martin Davis wrote:
>>> Ok, but equality is actually used in JTS too. Does Java have an
>>> automatic approximate equality ?
>> I've been working under the assumption that Java uses a single FP
>> model, so that it's safe to compare FP numbers.
>> In any case, I'm not sure that JTS uses FP equals for anything
>> other than checking whether two points are *exactly* the same.  So
>>  this should be portable, I assume.
> As far as you mean memory address comparison that would be portable
> (pointers are integer values). Unfortunately we don't have garbage
> collection for free in the C++ world, so in some places your identity
>  checks might have become value comparisons.
Hmm, there are pretty number of GCs for C++, e.g.:
http://www.hpl.hp.com/personal/Hans_Boehm/gc/
But Dear Friends, it would be humorous if GEOS should use real GC :-)
Then GEOS existence has completely no reason, because JTS is there.
p.s. Please note, that I'm quite suspicious about direct Java to C++
ports so my judgements in this subject are quite radical.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
