[geos-devel] MingW compilation errors and patches
Charlie Savage
cfis at savagexi.com
Mon Jun 26 05:21:57 EDT 2006
Three MingW compiling issues (this is gcc 3.4.5 on Windows). First one
I'm not sure what to do about, the other two I've attached patches. Let
me know if I should check them in .
1. The destructors in the .inl files seem to confuse ld. In the
linking stage there are about 10 errors like these:
libs/libgeos.lax/libalgorithm.a/MCPointInRing.o: In function
`ZN4geos9algorithm13MCPointInRing10MCSelecterD1Ev':C:/Development/msys/src/geos/source/algorithm/../../source/headers/geos/algorithm/PointInRing.h:(.text$_ZN4geos4geom11LineSegmentD1Ev[__ZN4geos4geom11LineSegmentD1Ev]+0x0):
multiple definition of `geos::geom::LineSegment::~LineSegment()'
.libs/inlines.o:C:/Development/msys/src/geos/source/../source/headers/geos/geom/LineSegment.inl:51:
first defined here
Any suggestions?
2. The finite function
g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
-I../../source/headers/geos -I../../source/headers -g -O2 -DGEOS_INLINE
-Wall -ansi -pedantic -Wno-long-long -MT HCoordinate.lo -MD -MP -MF
.deps/HCoordinate.Tpo -c HCoordinate.cpp -DDLL_EXPORT -DPIC -o
.libs/HCoordinate.o
HCoordinate.cpp: In member function `long double
geos::algorithm::HCoordinate::getX() const':
HCoordinate.cpp:188: error: `finite' was not declared in this scope
HCoordinate.cpp:188: warning: unused variable 'finite'
Patch:
Index: source/headers/geos/platform.h.in
RCS file: /home/cvs/postgis/geos/source/headers/geos/platform.h.in,v
retrieving revision 1.10
diff -u -r1.10 platform.h.in
--- source/headers/geos/platform.h.in 12 Jun 2006 13:57:54 -0000 1.10
+++ source/headers/geos/platform.h.in 26 Jun 2006 08:03:12 -0000
@@ -37,6 +37,10 @@
#define FINITE(x) ( (x) != DoubleNotANumber && (x) != DoubleInfinity
&& (x) != DoubleNegInfinity )
#define ISNAN(x) ( (x) == DoubleNotANumber )
+#if defined(__GNUC__) && defined(_WIN32)
+#define finite(x) FINITE(x)
+#endif
#ifdef HAVE_INT64_T_64
typedef int64_t int64;
#else
3. gettimeofday
-Wall -ansi -pedantic -Wno-long-long -MT CoordinateSequence.lo -MD -MP
-MF .deps/CoordinateSequence.Tpo -c CoordinateSequence.cpp -DDLL_EXPORT
-DPIC -o .libs/CoordinateSequence.o
In file included from ../../source/headers/geos/profiler.h:22,
from CoordinateSequence.cpp:17:
../../source/headers/geos/timeval.h: In function `int
gettimeofday(timeval*, timezone*)':
../../source/headers/geos/timeval.h:60: error: `tzset' was not declared
in this scope
../../source/headers/geos/timeval.h:60: warning: unused variable 'tzset'
../../source/headers/geos/timeval.h:63: error: `_timezone' was not
../../source/headers/geos/timeval.h:64: error: `_daylight' was not
../../source/headers/geos/timeval.h:63: warning: unused variable '_timezone'
../../source/headers/geos/timeval.h:64: warning: unused variable '_daylight'
Patch:
Index: source/headers/geos/timeval.h
RCS file: /home/cvs/postgis/geos/source/headers/geos/timeval.h,v
retrieving revision 1.3
diff -u -r1.3 timeval.h
--- source/headers/geos/timeval.h 20 Mar 2006 10:14:01 -0000 1.3
+++ source/headers/geos/timeval.h 26 Jun 2006 08:48:58 -0000
@@ -32,6 +32,16 @@
#endif /* _WIN32 */
+/* For MingW the appropriate definitions are included in
+ time.h but they are protected by the __STRICT_ANSI__
+ definition. Since GEOS is compiled with -ansi and
+ -pedantic, they don't get included. */
+#if defined(_WIN32) && defined(__GNUC__)
+extern _CRTIMP void __cdecl _tzset (void);
+__MINGW_IMPORT int _daylight;
+__MINGW_IMPORT long _timezone;
+#endif
#if defined(_WIN32) && !defined(_WIN32_WCE)
__inline int gettimeofday(struct timeval *tv, struct timezone *tz)
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060626/033d2c5f/smime.bin
