[geos-devel] MingW compilation errors and patches
strk at refractions.net
Mon Jun 26 06:50:18 EDT 2006
On Mon, Jun 26, 2006 at 03:21:57AM -0600, Charlie Savage wrote:
> Three MingW compiling issues (this is gcc 3.4.5 on Windows). First one
> I'm not sure what to do about, the other two I've attached patches. Let
> me know if I should check them in .
> 1. The destructors in the .inl files seem to confuse ld. In the
> linking stage there are about 10 errors like these:
> libs/libgeos.lax/libalgorithm.a/MCPointInRing.o: In function
> `ZN4geos9algorithm13MCPointInRing10MCSelecterD1Ev':C:/Development/msys/src/geos/source/algorithm/../../source/headers/geos/algorithm/PointInRing.h:(.text$_ZN4geos4geom11LineSegmentD1Ev[__ZN4geos4geom11LineSegmentD1Ev]+0x0):
> multiple definition of `geos::geom::LineSegment::~LineSegment()'
> .libs/inlines.o:C:/Development/msys/src/geos/source/../source/headers/geos/geom/LineSegment.inl:51:
> first defined here
> Any suggestions?
Is it a clean checkout ?
I guess the above can happen if you change GEOS_INLINES define
between different builds (deps problems).
> 2. The finite function
> g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> -I../../source/headers/geos -I../../source/headers -g -O2 -DGEOS_INLINE
> -Wall -ansi -pedantic -Wno-long-long -MT HCoordinate.lo -MD -MP -MF
> .deps/HCoordinate.Tpo -c HCoordinate.cpp -DDLL_EXPORT -DPIC -o
> .libs/HCoordinate.o
> HCoordinate.cpp: In member function `long double
> geos::algorithm::HCoordinate::getX() const':
> HCoordinate.cpp:188: error: `finite' was not declared in this scope
> HCoordinate.cpp:188: warning: unused variable 'finite'
FINITE() and finite() are really different functions, you should
make sure the math.h header is included whenever finite() is used.
Actually, the manual page states that _BSD_SOURCE must be defined.
If anyone knows of a standard C++ equivalent that'd be nice.
--strk;
