[geos-devel] MingW compilation errors and patches
Charlie Savage cfis at savagexi.com
Mon Jun 26 16:18:58 EDT 2006
>> Any suggestions?
> Is it a clean checkout ?
> I guess the above can happen if you change GEOS_INLINES define
> between different builds (deps problems).
Just to be sure, I deleted my copy of GEOS, and rechecked out.  Ran
./autogen.sh, then ./configure.  Same issue.  Its actually not just
constructors, for example:
.libs/libgeos.lax/libnoding.a/MCIndexSnapRounder.o: In function
`ZN4geos6noding9snapround18MCIndexSnapRounderD1Ev':C:/Development/msys/src/geos/source/noding/snapround/MCIndexSnapRounder.cpp:(.text$_ZNK4geos6noding9snapround18MCIndexSnapRounder18getNodedSubstringsEv[__ZNK4geos6noding9snapround18MCIndexSnapRounder18getNodedSubstringsEv]+0x0):
multiple definition of
`geos::noding::snapround::MCIndexSnapRounder::getNodedSubstrings() const'
Haven't touched the GEOS_INLINES define.
>> 2.  The finite function
> FINITE() and finite() are really different functions, you should
> make sure the math.h header is included whenever finite() is used.
> Actually, the manual page states that _BSD_SOURCE must be defined.
> If anyone knows of a standard C++ equivalent that'd be nice.
Ok, looked at this more.  This is the same issue as the time stuff.
MingW has the correct defines, but they are protected by the
__STRICT_ANSI__ define.  Right now, MingW compiles with -ansi so they
are not picked up.  I assume we want to keep it this way, so I've just
copied the appropriate definitions from the header like this:
#if defined(__GNUC__) && defined(_WIN32)
int __cdecl _finite (double);
#define finite(x) _finite(x)
#endif
So this now matches what VC++ does - hopefully thats better.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060626/718d2005/smime.bin
