[geos-devel] Unit Tests port
strk at refractions.net strk at refractions.net
Wed Mar 1 03:48:25 EST 2006
I vote for C++ unit testing as well.
Boost could be a good way to go as it's maybe time to
get boost into the dependency list for GEOS.
The shared_ptr<> template starts to get many points
in my mind.
--strk;
On Tue, Feb 28, 2006 at 07:19:39PM -0800, Paul Ramsey wrote:
> My sense of cleanliness says that the unit testing framework should
> be in the language being tested and not add build dependencies, but
> He Who Commits to the Effort has the most say.
> P
> On Feb 28, 2006, at 6:26 PM, alex bodnaru wrote:
> >hi,
> >i have heard today of a very flexible utf written in python.
> >see http://www.testoob.org.
> >alex
> >Mateusz Łoskot wrote:
> >>Hi,
> >>I started to think about porting JTS Unit Tests to C++ for GEOS.
> >>During dynamic development Unit Tests can be very helpful, they save
> >>much time and help to track bugs/fixes lifetime, and many many more.
> >>So, first, I think it's important to choose appropriate
> >>tool - Unit-Testing Framework (UTF).
> >>There are many UTFs so I'm a bit confused which would be best ;-)
> >>I'm going to make some short research in this field but I'd like
> >>to ask
> >>on the list if anyone has some prefered/recommended UTF and could
> >>present its pros/cons to make some comparison.
> >>My favourites are:
> >>1 - CxxTest - I have not used it, but it gots max votes in the
> >>article below
> >>http://cxxtest.sourceforge.net/
> >>2 - Boost.Test - quite complex but powerful
> >>http://www.boost.org/libs/test/doc/
> >>3 - TUT - very light and simple UTF
> >>http://tut-framework.sourceforge.net
> >>Here is interesting article exploring available UTFs
> >>(NOTE: this article is 2 years old):
> >>http://www.gamesfromwithin.com/articles/0412/000061.html
> >>Thanks for your comments!
> >>Cheers
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
State-collected Geographic Data is public property !
Reject the INSPIRE directive.
Sign the petition: http://petition.publicgeodata.org
