[geos-devel] boost
Mateusz Łoskot mateusz at loskot.net
Wed Mar 1 07:20:30 EST 2006
strk at refractions.net wrote:
>>>	- GEOS ABI was too weak, thus we provided
>>>	  a C-API interface to keep binary compatibility
>>>	  in the long term
>>Unfortunately, I can not get the idea of keeping
>>double APIs: C and C++ :-)))
>>If something is written in C++, why to bother with C?
> Becase we want some kind of insulation to keep binary compatibility
> until GEOS gets stable (could be a very long time).
Yes, that's important reason: GEOS is not stable enough to keep its API
unchanged during development. But there are many products using GEOS
already.
> Note that GEOS is an important module for PostGIS, and
> it is very nice for PostGIS users to be able to upgrade
> GEOS library w/out having to recompile PostGIS, as GEOS
> life cycle is very much different from PostGIS, which is
> a much stable piece of software.
Yes, I definitely understand this situation.
> Yes, it would have been possible to make the C++ ABI stable
> as well, but not havin done from the start makes it hard now.
Sure.
> A *full-C++* approach has been taken by GDAL. In that case
> within a single library you have both C and C++ entry points,
> with C ABI compatibility retained and C++ one pretty left
> to randomness. This brought to problems in 'encoding' library
> versions, as in a versioned library you must either declare compatibility
> or not with previoius versions, and you can't make distinctions
> between the two entry points.
That's the problem.
In COM/CORBA, interface is a contract which can not be changed in
future. Similarly, to DLL which exposes C++ interface. This interface
should be designed once and kept in future. Certainly, it's easier to
say than to do it ;-)))
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
