[geos-devel] Is NonRobustLineIntersector deprecated
Mateusz Łoskot mateusz at loskot.net
Thu Mar 2 17:04:14 EST 2006
I see there is file
/geos/source/algorithm/NonRobustLineIntersector.cpp
which seems to be unused.
I can't find class NonRobustLineIntersector definition or header file.
When I try to compile NonRobustLineIntersector.cpp I get many errors,
also that class NonRobustLineIntersector is not defined.
The same situation is with following files:
CoordinateList.cpp
Are they going to be removed from CVS?
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
