[geos-devel] First glance at the Unit Test
Mateusz Łoskot
mateusz at loskot.net
Sun Mar 5 20:16:24 EST 2006
I'm sending some example of single Test Suite with a bunch of Test Cases
based on Boost Unit Test Framework.
This Test Suite is dedicated to test Envelope class, so it's called
envelope_class_test suite.
It's based on EnvelopeTest.java - JTS version of test for JUnit.
I hope this small example will give some impression about how Boost UTF
can be incorporated in GEOS.
NOTE: I tested it with VC++ 8.0, so I don't have any makefiles for now,
only VC++ project files. If anyone is interested I can send VC++ 8.0
project files.
INSTRUCTIONS
1. Boost
I use current CVS - 1.34 but it should work well with current stable
1.33.1 release.
The *only* library used (that envelope_class_test is linked with) is
Unit Test Framework. It is only one binary file. In my case with VC++
8.0 I linked this example with
libboost_unit_test_framework-vc80-mt-gd-1_34.lib
So, on Linux yo have to link with file named as something like:
libboost_unit_test_framework-gcc-mt-gd-1_34.a
2.
Next, save the code included below as envelope_class_test.cpp file.
NOTE: there is no main function in the example test, so don't worry
Boost will provide appropriate one :-)
Check if gcc can find header used by the example:
#include <boost/test/unit_test.hpp>
Compile and link with library above.
For instructions about how to build Boost I'd suggest to refere to:
http://boost.org/more/getting_started.html
3. After it builds without any errors, just run it as a common executable.
4. You can change a bit checks in this exmaple to catch
some errors, e.g.: change
BOOST_CHECK( e1.isNull() );
to read as
BOOST_CHECK( !e1.isNull() );
Please note, this exmaple is not going to present all features of Boost
UTF. Simply, it's not possible in such a small piece of code :-)
After I've read whole Boost.Test documentation I only analyzed Unit Test
Framework (one of Boost.Test component) according to usage in GEOS,
so this example presents only basic idea of:
- how test cases set in Boost UTF look like
- how test suites look like
- what output you can get
- what are basic checks (macros)
There are many many more features which can be used to develop
sophisticated Unit Tests, cases and suits but I think we can explore
them later, after Boost.Test will be incorporated in GEOS.
So, I'm interested in your comments and suggestions.
Do you like it or not, should I procede with implementation of
the rest of tests?
Here is the file:
// envelope_class_test.cpp
// BOOST
#define BOOST_TEST_MODULE envelope_class_test
// GEOS
#include <geos/geom.h>
// Test Suite
BOOST_AUTO_TEST_SUITE( envelope_class_test );
BOOST_AUTO_TEST_CASE( envelope_constructors_test )
// 1 - default constructor
geos::Envelope e1;
BOOST_CHECK_EQUAL( e1.getWidth(), 0 );
BOOST_CHECK_EQUAL( e1.getHeight(), 0 );
// 2
geos::Envelope e2(100, 200, 100, 200);
BOOST_CHECK( !e2.isNull() );
BOOST_CHECK_EQUAL( e2.getMinX(), 100 );
BOOST_CHECK_EQUAL( e2.getMaxX(), 200 );
BOOST_CHECK_EQUAL( e2.getMinY(), 100 );
BOOST_CHECK_EQUAL( e2.getMaxY(), 200 );
BOOST_CHECK_EQUAL( e2.getWidth(), 100 );
BOOST_CHECK_EQUAL( e2.getHeight(), 100 );
// 3 - copy constructor
geos::Envelope e3(e2);
BOOST_CHECK( !e3.isNull() );
BOOST_CHECK_EQUAL( e3.getMinX(), 100 );
BOOST_CHECK_EQUAL( e3.getMaxX(), 200 );
BOOST_CHECK_EQUAL( e3.getMinY(), 100 );
BOOST_CHECK_EQUAL( e3.getMaxY(), 200 );
BOOST_CHECK_EQUAL( e3.getWidth(), 100 );
BOOST_CHECK_EQUAL( e3.getHeight(), 100 );
BOOST_CHECK( e3 == e2 );
BOOST_CHECK( e3.equals( &e2 ) );
} // envelope_constructors_test
BOOST_AUTO_TEST_CASE( envelope_null_test )
// 1 - Test isNull() and setToNull() functions
geos::Envelope e1(100, 200, 100, 200);
e1.setToNull();
} // envelope_null_test
BOOST_AUTO_TEST_CASE( envelope_equals_test )
// 1 - Test equals() function
geos::Envelope e3(1, 2, 1, 2);
BOOST_CHECK( e1.equals( &e2 ) );
BOOST_CHECK( !e1.equals( &e3 ) );
BOOST_CHECK( !e2.equals( &e3 ) );
} // envelope_equals_test
BOOST_AUTO_TEST_CASE( envelope_contains_test )
// Test contains() predicates
geos::Envelope e1;
geos::Envelope e2(-1, 1, -1, 1);
geos::Envelope e3(-5, 5, -5, 5);
// 1 - Test empty envelope by reference
BOOST_CHECK_MESSAGE( !e1.contains( e2 ), "e1 envelope is not empty!" );
BOOST_CHECK_MESSAGE( !e2.contains( e1 ), "e1 envelope is not empty!");
// 2 - Test empty envelope by pointer
BOOST_CHECK_MESSAGE( !e2.contains( &e1 ), "e1 envelope is not empty!");
BOOST_CHECK_MESSAGE( !e1.contains( &e2 ), "e1 envelope is not
empty!" );
// 3 - Test non-empty envelope by reference
BOOST_CHECK( !e2.contains( e3 ) );
BOOST_CHECK( e3.contains( e2 ) );
// 3 - Test raw point
BOOST_CHECK( e2.contains( 0, 0 ) );
BOOST_CHECK( e2.contains( -1, -1 ) );
BOOST_CHECK( !e2.contains( 5, 5 ) );
// 4 - Test coordinate
geos::Coordinate c1(0, 0, 0);
BOOST_REQUIRE_EQUAL( c1.x, 0 );
BOOST_REQUIRE_EQUAL( c1.y, 0 );
BOOST_REQUIRE_EQUAL( c1.z, 0 );
BOOST_CHECK( e2.contains( c1 ) );
} // envelope_contains_test
BOOST_AUTO_TEST_CASE( envelope_intersects_test )
// Test intersects() predicates
geos::Envelope e1;
geos::Envelope e2(-100, 100, -100, 100);
geos::Envelope e3(50, 150, 50, 150);
// 1 - Test empty envelope by pointer
BOOST_CHECK_MESSAGE( !e1.intersects( &e2 ), "e1 envelope is not
empty!" );
BOOST_CHECK_MESSAGE( !e2.intersects( &e1 ), "e1 envelope is not
empty!");
// 2 - Test empty envelope by reference
BOOST_CHECK_MESSAGE( !e1.intersects( e2 ), "e1 envelope is not
empty!" );
BOOST_CHECK_MESSAGE( !e2.intersects( e1 ), "e1 envelope is not
empty!");
// 3 - Test empty envelope by reference
BOOST_CHECK( e2.intersects( e3 ) );
BOOST_CHECK( e3.intersects( e2 ) );
// 3 - Test point
BOOST_CHECK( e2.intersects( 0, 0 ) );
BOOST_CHECK( e2.intersects( -100, 100 ) );
BOOST_CHECK( !e2.intersects( -200, 200 ) );
// XXX - add test for Coordinate
} // envelope_intersects_test
BOOST_AUTO_TEST_CASE( envelope_expand_test )
// TODO
BOOST_CHECK_MESSAGE( false, "TEST CASE NOT IMPLEMENTED" );
} //envelope_expand_test
BOOST_AUTO_TEST_SUITE_END(); // envelope_class_test
// EOF
Mateusz Łoskot
http://mateusz.loskot.net
