[geos-devel] First glance at the Unit Test
strk at refractions.net
Mon Mar 6 05:00:36 EST 2006
Does anybody have an m4 file that can be used
to detect availability of boost ?
I've found some online, but they don't seem to be checking
for the UTF library.
REF: http://lists.boost.org/Archives/boost/2005/12/98656.php
--strk;
On Mon, Mar 06, 2006 at 02:16:24AM +0100, Mateusz Å?oskot wrote:
> Hi,
> I'm sending some example of single Test Suite with a bunch of Test Cases
> based on Boost Unit Test Framework.
> This Test Suite is dedicated to test Envelope class, so it's called
> envelope_class_test suite.
> It's based on EnvelopeTest.java - JTS version of test for JUnit.
> I hope this small example will give some impression about how Boost UTF
> can be incorporated in GEOS.
> NOTE: I tested it with VC++ 8.0, so I don't have any makefiles for now,
> only VC++ project files. If anyone is interested I can send VC++ 8.0
> project files.
> INSTRUCTIONS
> 1. Boost
> I use current CVS - 1.34 but it should work well with current stable
> 1.33.1 release.
> The *only* library used (that envelope_class_test is linked with) is
> Unit Test Framework. It is only one binary file. In my case with VC++
> 8.0 I linked this example with
> libboost_unit_test_framework-vc80-mt-gd-1_34.lib
> So, on Linux yo have to link with file named as something like:
> libboost_unit_test_framework-gcc-mt-gd-1_34.a
> 2.
> Next, save the code included below as envelope_class_test.cpp file.
> NOTE: there is no main function in the example test, so don't worry
> Boost will provide appropriate one :-)
> Check if gcc can find header used by the example:
> #include <boost/test/unit_test.hpp>
> Compile and link with library above.
> For instructions about how to build Boost I'd suggest to refere to:
> http://boost.org/more/getting_started.html
> 3. After it builds without any errors, just run it as a common executable.
> 4. You can change a bit checks in this exmaple to catch
> some errors, e.g.: change
> BOOST_CHECK( e1.isNull() );
> to read as
> BOOST_CHECK( !e1.isNull() );
> Please note, this exmaple is not going to present all features of Boost
> UTF. Simply, it's not possible in such a small piece of code :-)
> After I've read whole Boost.Test documentation I only analyzed Unit Test
> Framework (one of Boost.Test component) according to usage in GEOS,
> so this example presents only basic idea of:
> - how test cases set in Boost UTF look like
> - how test suites look like
> - what output you can get
> - what are basic checks (macros)
> There are many many more features which can be used to develop
> sophisticated Unit Tests, cases and suits but I think we can explore
> them later, after Boost.Test will be incorporated in GEOS.
> So, I'm interested in your comments and suggestions.
> Do you like it or not, should I procede with implementation of
> the rest of tests?
> Here is the file:
> // envelope_class_test.cpp
> // BOOST
> #define BOOST_TEST_MODULE envelope_class_test
> // GEOS
> #include <geos/geom.h>
> // Test Suite
> BOOST_AUTO_TEST_SUITE( envelope_class_test );
> BOOST_AUTO_TEST_CASE( envelope_constructors_test )
> // 1 - default constructor
> geos::Envelope e1;
> BOOST_CHECK_EQUAL( e1.getWidth(), 0 );
> BOOST_CHECK_EQUAL( e1.getHeight(), 0 );
> // 2
> geos::Envelope e2(100, 200, 100, 200);
> BOOST_CHECK( !e2.isNull() );
> BOOST_CHECK_EQUAL( e2.getMinX(), 100 );
> BOOST_CHECK_EQUAL( e2.getMaxX(), 200 );
> BOOST_CHECK_EQUAL( e2.getMinY(), 100 );
> BOOST_CHECK_EQUAL( e2.getMaxY(), 200 );
> BOOST_CHECK_EQUAL( e2.getWidth(), 100 );
> BOOST_CHECK_EQUAL( e2.getHeight(), 100 );
> // 3 - copy constructor
> geos::Envelope e3(e2);
> BOOST_CHECK( !e3.isNull() );
> BOOST_CHECK_EQUAL( e3.getMinX(), 100 );
> BOOST_CHECK_EQUAL( e3.getMaxX(), 200 );
> BOOST_CHECK_EQUAL( e3.getMinY(), 100 );
> BOOST_CHECK_EQUAL( e3.getMaxY(), 200 );
> BOOST_CHECK_EQUAL( e3.getWidth(), 100 );
> BOOST_CHECK_EQUAL( e3.getHeight(), 100 );
> BOOST_CHECK( e3 == e2 );
> BOOST_CHECK( e3.equals( &e2 ) );
> } // envelope_constructors_test
> BOOST_AUTO_TEST_CASE( envelope_null_test )
> // 1 - Test isNull() and setToNull() functions
> geos::Envelope e1(100, 200, 100, 200);
> e1.setToNull();
> } // envelope_null_test
> BOOST_AUTO_TEST_CASE( envelope_equals_test )
> // 1 - Test equals() function
> geos::Envelope e3(1, 2, 1, 2);
> BOOST_CHECK( e1.equals( &e2 ) );
> BOOST_CHECK( !e1.equals( &e3 ) );
> BOOST_CHECK( !e2.equals( &e3 ) );
> } // envelope_equals_test
> BOOST_AUTO_TEST_CASE( envelope_contains_test )
> // Test contains() predicates
> geos::Envelope e1;
> geos::Envelope e2(-1, 1, -1, 1);
> geos::Envelope e3(-5, 5, -5, 5);
> // 1 - Test empty envelope by reference
> BOOST_CHECK_MESSAGE( !e1.contains( e2 ), "e1 envelope is not empty!" );
> BOOST_CHECK_MESSAGE( !e2.contains( e1 ), "e1 envelope is not empty!");
> // 2 - Test empty envelope by pointer
> BOOST_CHECK_MESSAGE( !e2.contains( &e1 ), "e1 envelope is not empty!");
> BOOST_CHECK_MESSAGE( !e1.contains( &e2 ), "e1 envelope is not
> empty!" );
> // 3 - Test non-empty envelope by reference
> BOOST_CHECK( !e2.contains( e3 ) );
> BOOST_CHECK( e3.contains( e2 ) );
> // 3 - Test raw point
> BOOST_CHECK( e2.contains( 0, 0 ) );
> BOOST_CHECK( e2.contains( -1, -1 ) );
> BOOST_CHECK( !e2.contains( 5, 5 ) );
> // 4 - Test coordinate
> geos::Coordinate c1(0, 0, 0);
> BOOST_REQUIRE_EQUAL( c1.x, 0 );
> BOOST_REQUIRE_EQUAL( c1.y, 0 );
> BOOST_REQUIRE_EQUAL( c1.z, 0 );
> BOOST_CHECK( e2.contains( c1 ) );
> } // envelope_contains_test
> BOOST_AUTO_TEST_CASE( envelope_intersects_test )
> // Test intersects() predicates
> geos::Envelope e1;
> geos::Envelope e2(-100, 100, -100, 100);
> geos::Envelope e3(50, 150, 50, 150);
> // 1 - Test empty envelope by pointer
> BOOST_CHECK_MESSAGE( !e1.intersects( &e2 ), "e1 envelope is not
> empty!" );
> BOOST_CHECK_MESSAGE( !e2.intersects( &e1 ), "e1 envelope is not
> empty!");
> // 2 - Test empty envelope by reference
> BOOST_CHECK_MESSAGE( !e1.intersects( e2 ), "e1 envelope is not
> empty!" );
> BOOST_CHECK_MESSAGE( !e2.intersects( e1 ), "e1 envelope is not
> empty!");
> // 3 - Test empty envelope by reference
> BOOST_CHECK( e2.intersects( e3 ) );
> BOOST_CHECK( e3.intersects( e2 ) );
> // 3 - Test point
> BOOST_CHECK( e2.intersects( 0, 0 ) );
> BOOST_CHECK( e2.intersects( -100, 100 ) );
> BOOST_CHECK( !e2.intersects( -200, 200 ) );
> // XXX - add test for Coordinate
> } // envelope_intersects_test
> BOOST_AUTO_TEST_CASE( envelope_expand_test )
> // TODO
> BOOST_CHECK_MESSAGE( false, "TEST CASE NOT IMPLEMENTED" );
> } //envelope_expand_test
> BOOST_AUTO_TEST_SUITE_END(); // envelope_class_test
> // EOF
> Mateusz Åoskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
State-collected Geographic Data is public property !
Reject the INSPIRE directive.
Sign the petition: http://petition.publicgeodata.org
