[geos-devel] [UTF] envelope_class_test.cpp fixed for Boost 1.33
strk at refractions.net
Mon Mar 13 06:09:45 EST 2006
Yep, I also feel this is going to be more complex then I imagined.
I always tried to do w/out boost exactly fearing for these kind
of problems (common when external dependencies are added).
Mateusz: how about boost-less port of the JTS unit tests instead ?
--strk;
On Sun, Mar 12, 2006 at 04:39:27PM -0800, Paul Ramsey wrote:
> The situation in general makes me wary, if Boost is going to changing
> incompatibly with some regularity. We want to use it to reduce
> workload, and it could potentially add workload.
> In the short term, can we simply wait for the 1.34 release as
> suggested? We have gotten this far with blackbox testing, we can
> hold on for a little longer. It would be interesting to know
> historically how often Boost has had incompatible changes.
> P
> On 12-Mar-06, at 3:03 PM, Mateusz Åoskot wrote:
> >Hi,
> >I'd like to ask you for your opinion about the issue
> >described in this thread.
> >It's very important for me, because I've had to stop portig Unit Tests
> >because I'd like not to do it twice.
> >So, please Leaders, share your ideas.
> >Thanks in advance
