[geos-devel] First example of Unit Tests with TUT
Mateusz Łoskot
mateusz at loskot.net
Thu Mar 16 07:05:07 EST 2006
strk at refractions.net wrote:
> On Thu, Mar 16, 2006 at 11:43:37AM +0100, Mateusz Å?oskot wrote:
>>As we discussed on the #postgis,
>>it could be usefull to divide unit test executables according to
>>GEOS namespaces.
>>So, that's not a problem but then geos_unit executable will be replaced
>>with separate programs per namespace.
>>Is this OK or you'd have different idea?
> I'm still unsure about this.
> I guess it's not important for now.
Yes, it isn't.
We can reorganize tests in every moment without rewriting anything.
> Let's move on with new tests.
Right.
> (your patch applied, unit tests are run by 'make check' now)
Yes, but the usage message does still disinform.
As I reported in #66, I'll fix it together with unifying to GNU style.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
