[geos-devel] First example of Unit Tests with TUT
strk at refractions.net strk at refractions.net
Thu Mar 16 06:10:30 EST 2006
On Thu, Mar 16, 2006 at 11:43:37AM +0100, Mateusz Å?oskot wrote:
> As we discussed on the #postgis,
> it could be usefull to divide unit test executables according to
> GEOS namespaces.
> So, that's not a problem but then geos_unit executable will be replaced
> with separate programs per namespace.
> Is this OK or you'd have different idea?
I'm still unsure about this.
I guess it's not important for now.
Let's move on with new tests.
(your patch applied, unit tests are run by 'make check' now)
--strk;
