[geos-devel] Namespaces and headers split
strk at refractions.net strk at refractions.net
Fri Mar 24 04:23:27 EST 2006
Yes, taking include out of source/ seems fine to me.
CAPI should still reside outside of the main src/ IMHO, as
it's really an additional interface, and a separate library.
Also, renaming 'source' to 'src' seems good.
Time for SVN ?
--strk;
On Fri, Mar 24, 2006 at 02:13:27AM +0100, Mateusz Å?oskot wrote:
> strk at refractions.net wrote:
> >I've completed the namespaces and headers split step.
> Great work!
> >GEOS namespaces now reflect JTS packages, and all classes are named
> >after JTS classes/interfaces. There are now duplicated names, but in
> >different namespaces (as it is for JTS).
> Are behind those duplicated names also duplicated types?
> If you don't mind, I'd have one more suggestion.
> Currently, the source tree is quite complex and the main trunk with
> implementation files (.cpp) includes its mirror in form of headers subdirs.
> Here is short example presenting how does it look like now:
> /geos/capi
> /geos/source/operation/buffer
> /geos/source/headers/geos
> /geos/source/headers/geos/operation/buffer
> So, as you can see, headers directory has the same structure
> (operation/buffer) but the only difference is that it contains headers
> (.h) files.
> Shortly, GEOS follows the concept clear separation of headers and
> implementation files, just like common GNU project structure, that includes:
> /project-name/src
> /project-name/include
> Now, my suggestion is to make GEOS' structure more clear by arranging it
> in real GNU style.
> Here is new version of the example above:
> /geos/src/capi
> /geos/src/operation/buffer
> /geos/include/capi
> /geos/include/operation/buffer
> In my opinion, the this could make the structure better readable and
> clear. As wall as less deep, so it's would make if easier to navigate
> through it.
> Note, that there would not be much problem with header files inclusion,
> because GEOS' implementation files use include path based on -I compiler
> definition.
> What do you think about my suggestion?
> Cheers
> Mateusz Łoskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
