[geos-devel] Petition for a 2.2.2 release
strk at refractions.net
Fri Mar 24 04:52:42 EST 2006
On Thu, Mar 23, 2006 at 08:34:47PM -0700, Sean Gillies wrote:
> >Please take a look at the HOW_TO_RELEASE file in HEAD.
> >It contains information on the process. It's a pretty
> >new file, so let me know if you have any question you'd
> >like to discuss.
> >Note that it has been written w/out thinking about a 2.2.2 release,
> >so I'm not sure about implications of the 2.2.2 release.
> >In particular, in HEAD we decided to name C++ library after release,
> >with every release breaking ABI with previous (libgeos-2.2.2.so).
> >The 2.2. branch shouldn't have this big change, so we should make it
> >binary-compatible with the previous, thus only incrementing MICRO
> >version (libgeos.so.2.2.2). We should check if everything goes as
> >expected still followin the same release process.
> >--strk;
> Alright, I've read it and seems fine, but your uncertainty about the
> implications confuses me. I've incremented VERSION_PATCH in
> configure.in to 2. Make install results in libgeos.so.2.2.2 and
> libgeos_c.so.1.0.2. I've made dist and verfied that the tarball will
> build and install. Can we tag it and release?
Sounds good to me, as a final test can you run 'make dist', build
and install from the resulting package ? Keep an eye to swig.
--strk;
