[geos-devel] Is empty LinearRing closed?
Martin Davis
mbdavis at VividSolutions.com
Thu Mar 30 17:42:19 EST 2006
I'm not sure why strk is making this comment. JTS/GEOS supports empty geometries of all types (as per the OGC SFS).
That said, what kind of empty geometry is returned from various methods is open to interpretation, I think. In some cases I think the best you can do is to return an empty GC. In other cases a more precise kind of empty geometry can be returned (and as I noted, JTS/GEOS could probably improve it's semantics in a few cases. )
Martin Davis, Senior Technical Architect
Vivid Solutions Inc. www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net
> [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
> Mateusz Loskot
> Sent: March 30, 2006 2:36 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] Is empty LinearRing closed?
> strk at refractions.net wrote:
> > The only valid EMPTY geometry would be a
> GEOMETRYCOLLECTION. All other
> > possibilities should be avoided IMO.
> Honestly, I don't like it.
> This is unclear and messed solution.
> What is the rationale to return instance of
> GeometryCollection where empty Point is expected?
> Cheers
> Mateusz Łoskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
