[geos-devel] Building geos-2.2.0 on fedora core 5
Mike Leahy mgleahy at alumni.uwaterloo.ca
Fri Mar 31 16:58:00 EST 2006
You're right...I didn't take notice of the './ChangeLog not found'
notice from the autogen output (below).  I ran 'touch ChangeLog', and
the error went away when I re-ran autogen, although those warnings about
underquoted definitions persist.  After that, ./configure and make both
worked fine.  I haven't done anything else to test it, but I imagine
it'll work fine.
Running autoheader
Running aclocal
/usr/share/aclocal/mpatrol.m4:37: warning: underquoted definition of
AM_WITH_MPATROL
  run info '(automake)Extending aclocal'
  or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
/usr/share/aclocal/libfame.m4:6: warning: underquoted definition of
AM_PATH_LIBFAME
Running libtoolize
Running automake
configure.in: installing `./install-sh'
configure.in: installing `./missing'
doc/Makefile.am: installing `./depcomp'
Makefile.am: required file `./ChangeLog' not found
Running autoconf
Now you are ready to run './configure'
strk at refractions.net wrote:
> On Fri, Mar 31, 2006 at 01:21:44PM -0500, Mike Leahy wrote:
>> I gave this a try - I got the geos cvs from branch-2-2, ran
>> ./autogen.sh, then ./configure...and got the following error at the end
>> of the configure:
>> config.status: creating Makefile
>> config.status: error: cannot find input file: Makefile.in
>> Is there a file missing, or did I miss something?
> Did you get any error from ./autogen.sh ?
> Makefile.in should be created from Makefile.am
> by automake run, invoked in autogen.sh.
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
