[geos-devel] GeometryFactory - call for explanation
Mateusz Łoskot
mateusz at loskot.net
Thu Mar 30 20:09:41 EST 2006
Could anyone explain/confirm me assumptions behind
the GeometryFactory class?
Depending on its semantic I'd have some proposal to refactor it.
Here are my qusetions:
Are following assumptions correct?
1. Ever instance of Geometry type (or its subtype) can have assigned its
own instance of GeometryFactory
2. One instance of GeometryFactory class can be shared (assigned to)
between more than one objects of Geometry class
3. It is not assumed that all geometries share the same
common instance of GeometryFactory
Thanks in advance for comments
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
