[geos-devel] Building geos-2.2.0 on fedora core 5 Again
Simon O'Malley simonom at gmail.com
Fri Mar 31 03:56:12 EST 2006
Hi Mike / Ari
Thanks for the pointer, compiling happily now.
Simon
On 3/31/06, Ari Jolma <ari.jolma at tkk.fi> wrote:
> I've succesfully compiled geos with Fedora 5 and the complete solution
> is as explained below.
> Ari
> Mike Leahy kirjoitti:
> > Hey Simon,
> > I haven't tried compiling geos on Fedora, but I've had similar problems
> > with other stuff - it's an issue with gcc-4.1.1 being more strict than
> > earlier versions.  If you can edit the source code that contains those
> > errors, and remove the unwanted 'extra qualifications'.  E.g., in the
> > file /source/headers/geos/geom.h on line 361, remove the text
> > "geos::Coordinate::" from the code...do the same for any similar extra
> > qualification errors.  After you clean up those errors, if you're lucky
> > it will compile, if you're less lucky, you'll find more extra
> > qualifications to clean up.  If you're unlucky, you'll find something
> > harder to deal with.
> > Good luck,
> > Mike
> > Simon O'Malley wrote:
> >> Hi All
> >> Not sure if this is a list or a gmail problem as this message never
> showed
> >> up. If this is a double post please ignore.
> >> Has anyone successfully built geos-2.2.0 on fedora core 5.
> >> I get the following errors when running make.
> >> [root at nazgul geos-2.2.0]# make
> >> Making all in source
> >> make[1]: Entering directory `/usr/src/postgres/geos-2.2.0/source'
> >> Making all in geom
> >> make[2]: Entering directory `/usr/src/postgres/geos-2.2.0/source/geom'
> >> if /bin/sh ../../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H
> -I.
> >> -I. -I../../source/headers -I../../source/headers/geos
> >> -I../../source/headers -DGEOS_VERSION=""2.2.0""    -g -O2 -MT
> >> Coordinate.lo-MD -MP -MF ".deps/Coordinate.Tpo" -c -o
> >> Coordinate.lo Coordinate.cpp; \
> >> then mv -f ".deps/Coordinate.Tpo" ".deps/Coordinate.Plo"; else rm -f
> >> ".deps/Coordinate.Tpo"; exit 1; fi
> >> mkdir .libs
> >>  g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> >> -I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.2.0-g
> >> -O2 -MT Coordinate.lo -MD -MP -MF .deps/Coordinate.Tpo -c
> Coordinate.cpp
> >> -fPIC -DPIC -o .libs/Coordinate.o
> >> ../../source/headers/geos/geom.h:361: error: extra qualification
> >> 'geos::Coordinate::' on member 'setNull'
> >> ../../source/headers/geos/geom.h:367: error: extra qualification
> >> 'geos::Coordinate::' on member 'getNull'
> >> ../../source/headers/geos/geom.h:371: error: extra qualification
> >> 'geos::Coordinate::' on member 'Coordinate'
> >> ../../source/headers/geos/geom.h:377: error: extra qualification
> >> ../../source/headers/geos/geom.h:384: error: extra qualification
> >> ../../source/headers/geos/geom.h:394: error: extra qualification
> >> ../../source/headers/geos/geom.h:400: error: extra qualification
> >> 'geos::Coordinate::' on member 'setCoordinate'
> >> ../../source/headers/geos/geom.h:406: error: extra qualification
> >> 'geos::Coordinate::' on member 'equals2D'
> >> ../../source/headers/geos/geom.h:416: error: extra qualification
> >> 'geos::Coordinate::' on member 'compareTo'
> >> ../../source/headers/geos/geom.h:432: error: extra qualification
> >> 'geos::Coordinate::' on member 'equals3D'
> >> ../../source/headers/geos/geom.h:436: error: extra qualification
> >> 'geos::Coordinate::' on member 'makePrecise'
> >> ../../source/headers/geos/geom.h:441: error: extra qualification
> >> 'geos::Coordinate::' on member 'distance'
> >> ../../source/headers/geos/geom.h:447: error: extra qualification
> >> 'geos::Coordinate::' on member 'hashCode'
> >> ../../source/headers/geos/geom.h:459: error: extra qualification
> >> make[2]: *** [Coordinate.lo] Error 1
> >> make[2]: Leaving directory `/usr/src/postgres/geos-2.2.0/source/geom'
> >> make[1]: *** [all-recursive] Error 1
> >> make[1]: Leaving directory `/usr/src/postgres/geos-2.2.0/source'
> >> make: *** [all-recursive] Error 1
> >> _______________________________________________
> >> geos-devel mailing list
> >> geos-devel at geos.refractions.net
> >> http://geos.refractions.net/mailman/listinfo/geos-devel
> Prof. Ari Jolma
> Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
> Teknillinen Korkeakoulu / Helsinki University of Technology
> POBox 1200, 02015 TKK, Finland
> Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20060331/f12413e2/attachment.html
