[geos-devel] GeometryFactory - call for explanation
Martin Davis
mbdavis at VividSolutions.com
Thu Mar 30 20:46:27 EST 2006
Good point about splitting the initial conditions out from the GeometryFactory. I was trying to reduce the number of classes - but maybe that's somewhat less flexible.
And yes, this is all trivial in Java - I commiserate with you C++ guys.... 8^)
I would think smart pointers would help here. As for a default factory, that probably makes a lot of sense for 98% of users - so seems like a good idea.
Martin
Martin Davis, Senior Technical Architect
Vivid Solutions Inc. www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
-----Original Message-----
From: geos-devel-bounces at geos.refractions.net [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of Charlie Savage
Sent: March 30, 2006 5:41 PM
To: GEOS Development List
Subject: Re: [geos-devel] GeometryFactory - call for explanation
Thanks for the explanation Martin. Seems like that is a workable design in Java, where the garbage collector worries about freeing the factories for you when they are no longer referenced by any geometries. I suppose I would probably split out the initial conditions into some other object - so the factory just creates geometries. But in the end, that doesn't change the issue I brought up.
So, in C++ Geos could we use smart pointers to achieve the same effect? And maybe add in a default global factory?
Charlie
Martin Davis wrote:
Those assumptions are correct.
There were two main reason for designing the GeometryFactory concept:
1) Provide a convenient, single location for defining the various "initial conditions" for Geometries. This includes the Precision Model, the CoordinateSequenceFactory, and sometimes the SRID. It may be extended in the future to contain things like which Polygon model to use, and preferences for precision handling.
2) Reduce the memory overhead of Geometries by moving relatively static objects (references) out of the Geometry and into a single shared object.
Hopefully this makes sense... But if anyone has good opinions about another design pattern, send them along.
Mateusz Loskot
Sent: March 30, 2006 5:10 PM
Subject: [geos-devel] GeometryFactory - call for explanation
Could anyone explain/confirm me assumptions behind
the GeometryFactory class?
Depending on its semantic I'd have some proposal to refactor
it. Here are my qusetions:
Are following assumptions correct?
1. Ever instance of Geometry type (or its subtype) can have
assigned its own instance of GeometryFactory
2. One instance of GeometryFactory class can be shared
(assigned to) between more than one objects of Geometry class
3. It is not assumed that all geometries share the same
common instance of GeometryFactory
Thanks in advance for comments
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
geos-devel mailing list
geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20060330/d41429b3/attachment.html
