[geos-devel] Building geos-2.2.0 on fedora core 5
strk at refractions.net
Fri Mar 31 03:02:01 EST 2006
2.2.1 should have fixed this, could you give it a try ?
TIA
--strk;
On Fri, Mar 31, 2006 at 10:29:02AM +1200, Simon O'Malley wrote:
> Hi All
> I wont confess to being a developer so hopefully there is someone on the
> list who can help.
> Has anyone successfully built geos-2.2.0 on fedora core 5.
> I get the following errors when running make.
> [root at nazgul geos-2.2.0]# make
> Making all in source
> make[1]: Entering directory `/usr/src/postgres/geos-2.2.0/source'
> Making all in geom
> make[2]: Entering directory `/usr/src/postgres/geos-2.2.0/source/geom'
> if /bin/sh ../../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I.
> -I. -I../../source/headers -I../../source/headers/geos
> -I../../source/headers -DGEOS_VERSION=""2.2.0"" -g -O2 -MT
> Coordinate.lo-MD -MP -MF ".deps/Coordinate.Tpo" -c -o
> Coordinate.lo Coordinate.cpp; \
> then mv -f ".deps/Coordinate.Tpo" ".deps/Coordinate.Plo"; else rm -f
> ".deps/Coordinate.Tpo"; exit 1; fi
> mkdir .libs
> g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> -I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.2.0 -g
> -O2 -MT Coordinate.lo -MD -MP -MF .deps/Coordinate.Tpo -c Coordinate.cpp
> -fPIC -DPIC -o .libs/Coordinate.o
> ../../source/headers/geos/geom.h:361: error: extra qualification
> 'geos::Coordinate::' on member 'setNull'
> ../../source/headers/geos/geom.h:367: error: extra qualification
> 'geos::Coordinate::' on member 'getNull'
> ../../source/headers/geos/geom.h:371: error: extra qualification
> 'geos::Coordinate::' on member 'Coordinate'
> ../../source/headers/geos/geom.h:377: error: extra qualification
> ../../source/headers/geos/geom.h:384: error: extra qualification
> ../../source/headers/geos/geom.h:394: error: extra qualification
> ../../source/headers/geos/geom.h:400: error: extra qualification
> 'geos::Coordinate::' on member 'setCoordinate'
> ../../source/headers/geos/geom.h:406: error: extra qualification
> 'geos::Coordinate::' on member 'equals2D'
> ../../source/headers/geos/geom.h:416: error: extra qualification
> 'geos::Coordinate::' on member 'compareTo'
> ../../source/headers/geos/geom.h:432: error: extra qualification
> 'geos::Coordinate::' on member 'equals3D'
> ../../source/headers/geos/geom.h:436: error: extra qualification
> 'geos::Coordinate::' on member 'makePrecise'
> ../../source/headers/geos/geom.h:441: error: extra qualification
> 'geos::Coordinate::' on member 'distance'
> ../../source/headers/geos/geom.h:447: error: extra qualification
> 'geos::Coordinate::' on member 'hashCode'
> ../../source/headers/geos/geom.h:459: error: extra qualification
> make[2]: *** [Coordinate.lo] Error 1
> make[2]: Leaving directory `/usr/src/postgres/geos-2.2.0/source/geom'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/src/postgres/geos-2.2.0/source'
> make: *** [all-recursive] Error 1
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
