[geos-devel] Building geos-2.2.0 on fedora core 5
Simon O'Malley
simonom at gmail.com
Fri Mar 31 03:27:12 EST 2006
Hi strk
Same error with 2.2.1
Simon
On 3/31/06, strk at refractions.net <strk at refractions.net> wrote:
> 2.2.1 should have fixed this, could you give it a try ?
> TIA
> --strk;
> On Fri, Mar 31, 2006 at 10:29:02AM +1200, Simon O'Malley wrote:
> > Hi All
> > I wont confess to being a developer so hopefully there is someone on the
> > list who can help.
> > Has anyone successfully built geos-2.2.0 on fedora core 5.
> > I get the following errors when running make.
> > [root at nazgul geos-2.2.0]# make
> > Making all in source
> > make[1]: Entering directory `/usr/src/postgres/geos-2.2.0/source'
> > Making all in geom
> > make[2]: Entering directory `/usr/src/postgres/geos-2.2.0/source/geom'
> > if /bin/sh ../../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H
> -I.
> > -I. -I../../source/headers -I../../source/headers/geos
> > -I../../source/headers -DGEOS_VERSION=""2.2.0"" -g -O2 -MT
> > Coordinate.lo-MD -MP -MF ".deps/Coordinate.Tpo" -c -o
> > Coordinate.lo Coordinate.cpp; \
> > then mv -f ".deps/Coordinate.Tpo" ".deps/Coordinate.Plo"; else rm -f
> > ".deps/Coordinate.Tpo"; exit 1; fi
> > mkdir .libs
> > g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> > -I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.2.0-g
> > -O2 -MT Coordinate.lo -MD -MP -MF .deps/Coordinate.Tpo -c Coordinate.cpp
> > -fPIC -DPIC -o .libs/Coordinate.o
> > ../../source/headers/geos/geom.h:361: error: extra qualification
> > 'geos::Coordinate::' on member 'setNull'
> > ../../source/headers/geos/geom.h:367: error: extra qualification
> > 'geos::Coordinate::' on member 'getNull'
> > ../../source/headers/geos/geom.h:371: error: extra qualification
> > 'geos::Coordinate::' on member 'Coordinate'
> > ../../source/headers/geos/geom.h:377: error: extra qualification
> > ../../source/headers/geos/geom.h:384: error: extra qualification
> > ../../source/headers/geos/geom.h:394: error: extra qualification
> > ../../source/headers/geos/geom.h:400: error: extra qualification
> > 'geos::Coordinate::' on member 'setCoordinate'
> > ../../source/headers/geos/geom.h:406: error: extra qualification
> > 'geos::Coordinate::' on member 'equals2D'
> > ../../source/headers/geos/geom.h:416: error: extra qualification
> > 'geos::Coordinate::' on member 'compareTo'
> > ../../source/headers/geos/geom.h:432: error: extra qualification
> > 'geos::Coordinate::' on member 'equals3D'
> > ../../source/headers/geos/geom.h:436: error: extra qualification
> > 'geos::Coordinate::' on member 'makePrecise'
> > ../../source/headers/geos/geom.h:441: error: extra qualification
> > 'geos::Coordinate::' on member 'distance'
> > ../../source/headers/geos/geom.h:447: error: extra qualification
> > 'geos::Coordinate::' on member 'hashCode'
> > ../../source/headers/geos/geom.h:459: error: extra qualification
> > make[2]: *** [Coordinate.lo] Error 1
> > make[2]: Leaving directory `/usr/src/postgres/geos-2.2.0/source/geom'
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory `/usr/src/postgres/geos-2.2.0/source'
> > make: *** [all-recursive] Error 1
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
> /"\ ASCII Ribbon Campaign
> \ / Respect for low technology.
> X Keep e-mail messages readable by any computer system.
> / \ Keep it ASCII.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20060331/a45b1091/attachment.html
