[geos-devel] GEOS 2.2.1 Compile Solaris10
Shaun Kolomeitz
shaun.kolomeitz at epa.qld.gov.au
Thu May 4 21:11:11 EDT 2006
Dear GEOS Dev List,
I think I've managed to get further with my compile issues (see below), but still bo cigar I'm afraid.
Any suggestions?
TIA,
Shaun
----8<----
(cd .libs && rm -f libgeos.so.2 && ln -s libgeos.so.2.2.1 libgeos.so.2)
(cd .libs && rm -f libgeos.so && ln -s libgeos.so.2.2.1 libgeos.so)
false cru .libs/libgeos.a Coordinate.o CoordinateSequence.o CoordinateSequenceFactory.o DefaultCoordinateSequence.o DefaultCoordinateSequenceFactory.o PointCoordinateSequenceFactory.o PointCoordinateSequence.o Dimension.o Envelope.o Geometry.o GeometryCollection.o GeometryCollectionIterator.o GeometryComponentFilter.o GeometryFactory.o IntersectionMatrix.o LinearRing.o LineSegment.o LineString.o Location.o MultiLineString.o MultiPoint.o MultiPolygon.o Point.o Polygon.o PrecisionModel.o TopologyException.o Triangle.o GeometryEditor.o LinearComponentExtracter.o PointExtracter.o PolygonExtracter.o CGAlgorithms.o CentroidArea.o CentroidLine.o CentroidPoint.o ConvexHull.o HCoordinate.o InteriorPointArea.o InteriorPointLine.o InteriorPointPoint.o LineIntersector.o MCPointInRing.o MinimumDiameter.o NonRobustCGAlgorithms.o NonRobustLineIntersector.o NotRepresentableException.o PointLocator.o RobustCGAlgorithms.o RobustDeterminant.o RobustLineIntersector.o SIRtreePointInRing.o SimplePointInAreaLocator.o SimplePointInRing.o CommonBits.o CommonBitsOp.o CommonBitsRemover.o EnhancedPrecisionOp.o SimpleGeometryPrecisionReducer.o Depth.o DirectedEdge.o DirectedEdgeStar.o Edge.o EdgeEnd.o EdgeEndStar.o EdgeIntersection.o EdgeIntersectionList.o EdgeNodingValidator.o EdgeList.o EdgeRing.o GeometryGraph.o GraphComponent.o Label.o Node.o NodeFactory.o NodeMap.o PlanarGraph.o Position.o Quadrant.o TopologyLocation.o MonotoneChain.o MonotoneChainEdge.o MonotoneChainIndexer.o SegmentIntersector.o SimpleEdgeSetIntersector.o SimpleMCSweepLineIntersector.o SimpleSweepLineIntersector.o SweepLineEvent.o SweepLineSegment.o Bintree.o BinTreeInterval.o BinTreeNode.o Key.o NodeBase.o Root.o indexMonotoneChain.o MonotoneChainBuilder.o MonotoneChainOverlapAction.o MonotoneChainSelectAction.o DoubleBits.o IntervalSize.o Quadtree.o QuadTreeKey.o QuadTreeNode.o QuadTreeNodeBase.o QuadTreeRoot.o AbstractNode.o AbstractSTRtree.o Interval.o ItemBoundable.o SIRtree.o STRtree.o indexSweepLineEvent.o SweepLineIndex.o SweepLineInterval.o ParseException.o StringTokenizer.o WKTReader.o WKTWriter.o WKBReader.o WKBWriter.o ByteOrderValues.o Writer.o Unload.o GeometryGraphOperation.o IsSimpleOp.o BufferBuilder.o BufferOp.o BufferSubgraph.o OffsetCurveBuilder.o OffsetCurveSetBuilder.o RightmostEdgeFinder.o SubgraphDepthLocater.o ConnectedElementLocationFilter.o ConnectedElementPointFilter.o DistanceOp.o GeometryLocation.o EdgeSetNoder.o LineBuilder.o MaximalEdgeRing.o MinimalEdgeRing.o OverlayNodeFactory.o OverlayOp.o PointBuilder.o PolygonBuilder.o ElevationMatrix.o ElevationMatrixCell.o ElevationMatrixFilter.o EdgeEndBuilder.o EdgeEndBundle.o EdgeEndBundleStar.o RelateComputer.o RelateNode.o RelateNodeFactory.o RelateNodeGraph.o RelateOp.o ConnectedInteriorTester.o ConsistentAreaTester.o IsValidOp.o QuadtreeNestedRingTester.o RepeatedPointTester.o SimpleNestedRingTester.o SweeplineNestedRingTester.o TopologyValidationError.o EdgeString.o LineMergeDirectedEdge.o LineMergeEdge.o LineMergeGraph.o LineMerger.o PolygonizeDirectedEdge.o PolygonizeEdge.o PolygonizeGraph.o Polygonizer.o polygonizeEdgeRing.o planarDirectedEdge.o planarDirectedEdgeStar.o planarEdge.o planarGraphComponent.o planarNode.o planarNodeMap.o planarPlanarGraph.o IteratedNoder.o MCQuadtreeNoder.o Noder.o NodingValidator.o SegmentNode.o SegmentNodeList.o SegmentString.o SimpleNoder.o nodingSegmentIntersector.o SegmentSnapper.o SimpleSegmentStringsSnapper.o SnapRounder.o Assert.o AssertionFailedException.o CoordinateArrayFiter.o GEOSException.o IllegalArgumentException.o UniqueCoordinateArrayFilter.o UnsupportedOperationException.o GeometricShapeFactory.o Profiler.o
*** Error code 1
make: Fatal error: Command failed for target `libgeos.la'
Current working directory /export/home/postgres/geos-2.2.1/source/geom
*** Error code 1
The following command caused the error:
set fnord $MAKEFLAGS; amf=$2; \
dot_seen=no; \
target=`echo all-recursive | sed s/-recursive//`; \
list='geom headers bigtest capi test'; for subdir in $list; do \
echo "Making $target in $subdir"; \
if test "$subdir" = "."; then \
dot_seen=yes; \
local_target="$target-am"; \
else \
local_target="$target"; \
fi; \
(cd $subdir && make $local_target) \
|| case "$amf" in *=*) exit 1;; *k*) fail=yes;; *) exit 1;; esac; \
done; \
if test "$dot_seen" = "no"; then \
make "$target-am" || exit 1; \
fi; test -z "$fail"
make: Fatal error: Command failed for target `all-recursive'
*** Error code 1
dot_seen=no; \
list='source macros tools swig doc VisualStudio'; for subdir in $list; do \
dot_seen=yes; \
else \
fi; \
done; \
fi; test -z "$fail"
___________________________
Disclaimer
This e-mail, including attachments if any, has originated from a Queensland government agency and may contain information that is confidential, or covered by legal professional privilege, and is intended for the named recipient(s) only. If you have received this message in error, you are asked to inform the sender as quickly as possible and delete this message and any copies of this message from your computer system network.
Any form of disclosure, modification, distribution and/or publication of this e-mail, including attachments is prohibited. Unless otherwise stated, this e-mail, including attachments represents the views of the sender and not the views of the Environmental Protection Agency.
Although this e-mail has been checked for the presence of computer viruses, the Environmental Protection Agency provides no warranty that all possible viruses have been detected and cleaned. Any use of this e-mail could harm your computer system.
