[geos-devel] GEOS 2.2.1 Compile Solaris10
Paul Ramsey
pramsey at refractions.net
Sun May 7 13:05:43 EDT 2006
Random guess, it looks like "make" itself is failing... are you using
the Solaris make, or a downloaded gmake? (You want the latter, it's
more full-featured...)
P
On 4-May-06, at 6:11 PM, Shaun Kolomeitz wrote:
> Dear GEOS Dev List,
> I think I've managed to get further with my compile issues (see
> below), but still bo cigar I'm afraid.
> Any suggestions?
> TIA,
> Shaun
> ----8<----
> (cd .libs && rm -f libgeos.so.2 && ln -s libgeos.so.2.2.1
> libgeos.so.2)
> (cd .libs && rm -f libgeos.so && ln -s libgeos.so.2.2.1 libgeos.so)
> false cru .libs/libgeos.a Coordinate.o CoordinateSequence.o
> CoordinateSequenceFactory.o DefaultCoordinateSequence.o
> DefaultCoordinateSequenceFactory.o PointCoordinateSequenceFactory.o
> PointCoordinateSequence.o Dimension.o Envelope.o Geometry.o
> GeometryCollection.o GeometryCollectionIterator.o
> GeometryComponentFilter.o GeometryFactory.o IntersectionMatrix.o
> LinearRing.o LineSegment.o LineString.o Location.o
> MultiLineString.o MultiPoint.o MultiPolygon.o Point.o Polygon.o
> PrecisionModel.o TopologyException.o Triangle.o GeometryEditor.o
> LinearComponentExtracter.o PointExtracter.o PolygonExtracter.o
> CGAlgorithms.o CentroidArea.o CentroidLine.o CentroidPoint.o
> ConvexHull.o HCoordinate.o InteriorPointArea.o InteriorPointLine.o
> InteriorPointPoint.o LineIntersector.o MCPointInRing.o
> MinimumDiameter.o NonRobustCGAlgorithms.o
> NonRobustLineIntersector.o NotRepresentableException.o
> PointLocator.o RobustCGAlgorithms.o RobustDeterminant.o
> RobustLineIntersector.o SIRtreePointInRing.o
> SimplePointInAreaLocator.o SimplePointInRing.o CommonBits.o
> CommonBitsOp.o CommonBitsRemover.o EnhancedPrecisionOp.o
> SimpleGeometryPrecisionReducer.o Depth.o DirectedEdge.o
> DirectedEdgeStar.o Edge.o EdgeEnd.o EdgeEndStar.o
> EdgeIntersection.o EdgeIntersectionList.o EdgeNodingValidator.o
> EdgeList.o EdgeRing.o GeometryGraph.o GraphComponent.o Label.o
> Node.o NodeFactory.o NodeMap.o PlanarGraph.o Position.o Quadrant.o
> TopologyLocation.o MonotoneChain.o MonotoneChainEdge.o
> MonotoneChainIndexer.o SegmentIntersector.o
> SimpleEdgeSetIntersector.o SimpleMCSweepLineIntersector.o
> SimpleSweepLineIntersector.o SweepLineEvent.o SweepLineSegment.o
> Bintree.o BinTreeInterval.o BinTreeNode.o Key.o NodeBase.o Root.o
> indexMonotoneChain.o MonotoneChainBuilder.o
> MonotoneChainOverlapAction.o MonotoneChainSelectAction.o
> DoubleBits.o IntervalSize.o Quadtree.o QuadTreeKey.o QuadTreeNode.o
> QuadTreeNodeBase.o QuadTreeRoot.o AbstractNode.o AbstractSTRtree.o
> Interval.o ItemBoundable.o SIRtree.o STRtree.o
> indexSweepLineEvent.o SweepLineIndex.o SweepLineInterval.o
> ParseException.o StringTokenizer.o WKTReader.o WKTWriter.o
> WKBReader.o WKBWriter.o ByteOrderValues.o Writer.o Unload.o
> GeometryGraphOperation.o IsSimpleOp.o BufferBuilder.o BufferOp.o
> BufferSubgraph.o OffsetCurveBuilder.o OffsetCurveSetBuilder.o
> RightmostEdgeFinder.o SubgraphDepthLocater.o
> ConnectedElementLocationFilter.o ConnectedElementPointFilter.o
> DistanceOp.o GeometryLocation.o EdgeSetNoder.o LineBuilder.o
> MaximalEdgeRing.o MinimalEdgeRing.o OverlayNodeFactory.o
> OverlayOp.o PointBuilder.o PolygonBuilder.o ElevationMatrix.o
> ElevationMatrixCell.o ElevationMatrixFilter.o EdgeEndBuilder.o
> EdgeEndBundle.o EdgeEndBundleStar.o RelateComputer.o RelateNode.o
> RelateNodeFactory.o RelateNodeGraph.o RelateOp.o
> ConnectedInteriorTester.o ConsistentAreaTester.o IsValidOp.o
> QuadtreeNestedRingTester.o RepeatedPointTester.o
> SimpleNestedRingTester.o SweeplineNestedRingTester.o
> TopologyValidationError.o EdgeString.o LineMergeDirectedEdge.o
> LineMergeEdge.o LineMergeGraph.o LineMerger.o
> PolygonizeDirectedEdge.o PolygonizeEdge.o PolygonizeGraph.o
> Polygonizer.o polygonizeEdgeRing.o planarDirectedEdge.o
> planarDirectedEdgeStar.o planarEdge.o planarGraphComponent.o
> planarNode.o planarNodeMap.o planarPlanarGraph.o IteratedNoder.o
> MCQuadtreeNoder.o Noder.o NodingValidator.o SegmentNode.o
> SegmentNodeList.o SegmentString.o SimpleNoder.o
> nodingSegmentIntersector.o SegmentSnapper.o
> SimpleSegmentStringsSnapper.o SnapRounder.o Assert.o
> AssertionFailedException.o CoordinateArrayFiter.o GEOSException.o
> IllegalArgumentException.o UniqueCoordinateArrayFilter.o
> UnsupportedOperationException.o GeometricShapeFactory.o Profiler.o
> *** Error code 1
> make: Fatal error: Command failed for target `libgeos.la'
> Current working directory /export/home/postgres/geos-2.2.1/source/geom
> *** Error code 1
> The following command caused the error:
> set fnord $MAKEFLAGS; amf=$2; \
> dot_seen=no; \
> target=`echo all-recursive | sed s/-recursive//`; \
> list='geom headers bigtest capi test'; for subdir in $list; do \
> echo "Making $target in $subdir"; \
> if test "$subdir" = "."; then \
> dot_seen=yes; \
> local_target="$target-am"; \
> else \
> local_target="$target"; \
> fi; \
> (cd $subdir && make $local_target) \
> || case "$amf" in *=*) exit 1;; *k*) fail=yes;; *) exit 1;; esac; \
> done; \
> if test "$dot_seen" = "no"; then \
> make "$target-am" || exit 1; \
> fi; test -z "$fail"
> make: Fatal error: Command failed for target `all-recursive'
> *** Error code 1
> dot_seen=no; \
> list='source macros tools swig doc VisualStudio'; for subdir
> in $list; do \
> dot_seen=yes; \
> else \
> fi; \
> done; \
> fi; test -z "$fail"
> ___________________________
> Disclaimer
> This e-mail, including attachments if any, has originated from a
> Queensland government agency and may contain information that is
> confidential, or covered by legal professional privilege, and is
> intended for the named recipient(s) only. If you have received
> this message in error, you are asked to inform the sender as
> quickly as possible and delete this message and any copies of this
> message from your computer system network.
> Any form of disclosure, modification, distribution and/or
> publication of this e-mail, including attachments is prohibited.
> Unless otherwise stated, this e-mail, including attachments
> represents the views of the sender and not the views of the
> Environmental Protection Agency.
> Although this e-mail has been checked for the presence of computer
> viruses, the Environmental Protection Agency provides no warranty
> that all possible viruses have been detected and cleaned. Any use
> of this e-mail could harm your computer system.
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
