[geos-devel] left and right buffer
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 17 13:06:07 EDT 2006
Hi Martin,
I think a useful variant of this for polygons it to be able to specify
inside or outside, so you could effectively grow and shrink the polygon.
The "grow" option is great for finding abutters, and I think the buffer
command today already does this.
The "shrink" option is great for defining/showing boundary offsets
within a lot that might be needed to insure zoning rules.
-Steve
Martin Davis wrote:
> I'm curious what your use case is for this functionality. Can you post
> some sample data that you want L/R buffers for, and perhaps an image of
> what you expect the results to look like?
> Martin Davis, Senior Technical Architect
> Vivid Solutions Inc. www.vividsolutions.com
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
>>-----Original Message-----
>>From: geos-devel-bounces at geos.refractions.net
>>[mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
>>zhangjing
>>Sent: May 17, 2006 12:10 AM
>>To: geos-devel at geos.refractions.net
>>Subject: [geos-devel] left and right buffer
>>hi,
>>Is there any way in GEOS to calculate geometry's left or
>>right buffer ?
>>TIA
>>Jing Zhang
>>_______________________________________________
>>geos-devel mailing list
>>http://geos.refractions.net/mailman/listinfo/g> eos-devel
> http://geos.refractions.net/mailman/listinfo/geos-devel
