[geos-devel] left and right buffer
Martin Davis
mbdavis at VividSolutions.com
Wed May 17 13:21:27 EDT 2006
Am I missing something? Isn't this the functionality that negative
buffer distances gives today?
Martin Davis, Senior Technical Architect
Vivid Solutions Inc. www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net
> [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
> Stephen Woodbridge
> Sent: May 17, 2006 10:06 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] left and right buffer
> Hi Martin,
> I think a useful variant of this for polygons it to be able
> to specify
> inside or outside, so you could effectively grow and shrink
> the polygon.
> The "grow" option is great for finding abutters, and I think
> the buffer
> command today already does this.
> The "shrink" option is great for defining/showing boundary offsets
> within a lot that might be needed to insure zoning rules.
> -Steve
> Martin Davis wrote:
> > I'm curious what your use case is for this functionality. Can you
> > post some sample data that you want L/R buffers for, and perhaps an
> > image of what you expect the results to look like?
> >>zhangjing
> >>Sent: May 17, 2006 12:10 AM
> >>To: geos-devel at geos.refractions.net
> >>Subject: [geos-devel] left and right buffer
> >>hi,
> >>Is there any way in GEOS to calculate geometry's left or
> >>right buffer ?
> >>TIA
> >>Jing Zhang
> >>_______________________________________________
> >>geos-devel mailing list
> >>http://geos.refractions.net/mailman/listinfo/g> eos-devel
> > http://geos.refractions.net/mailman/listinfo/geos-devel
