[geos-devel] Re: Problems with installation of geos on RedHat 9 (third try, i hope this is text)
Johan V aragorn_jv at yahoo.com
Sat May 20 06:39:21 EDT 2006
I hope you know the solution to this problems, I'm not a linux expert
like you maybe already noticed, but if you can tell me what I'm doing
wrong that would be great
Thx,
Johan
2006/5/18, Johan V <jvhoppli at gmail.com>:
> If i run ./autogen.sh (after doing a chmod +775 autogen.sh) i get
> : bad interpreter: No such file or directory
> If i look at this shell script and i try to execute the command one by
> one, than i get:
> [root at 192 geos]# uname -s
> Linux
> [root at 192 geos]# autoheader
> ' is already registered with AC_CONFIG_FILES.
> autoconf/status.m4:844: AC_CONFIG_FILES is expanded from...
> configure.in:271: the top level
> autom4te: /usr/bin/m4 failed with exit status: 1
> autoheader: /usr/bin/autom4te failed with exit status: 1
> [root at 192 geos]# aclocal -I macros
> [root at 192 geos]# libtoolize --force --copy
> [root at 192 geos]# automake --add-missing --copy
> configure.in:31: `automake requires `AM_CONFIG_HEADER', not `AC_CONFIG_HEADER'
> configure.in: installing `./mkinstalldirs'
> configure.in: installing `./missing'
> aclocal.m4:4665: installing `./py-compile'
> capi/Makefile.am: installing `./depcomp'
> configure.in:32: required file `source/headers/config.h.in' not found
> 2006/5/18, strk at refractions.net <strk at refractions.net>:
> > On Thu, May 18, 2006 at 02:31:42PM +0200, Johan V wrote:
> > > I downloaded the latest snapshot from the website (the tar.bz file),
> > > so not with the cvs commando. So now, I tried to do it with cvs (via
> > > another person's internet connection, because i'm behind a proxy
> > > server, and don't now how to configure cvs correctly), but in de
> > > directory geos there is no configure file nor a Makefile, only an
> > > configure.in and a Makefile.am, and neither are those files in the
> > > source subdirectory (only config.log and Makefile.am and Makefile.vc).
> > > Is it possible to put the latest snapshot as a tar.bz file on the
> > > website please.
> > Run ./autogen.sh in your working directory.
> > --strk;
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
