[geos-devel] GEOS-3.0.0rc2
strk at refractions.net
Sat Nov 4 04:51:44 EST 2006
Charlie, do you think you can fix this shortly ?
(otherwise I'd ship rc2 with *known* broken swig bindings)
--strk;
On Sat, Nov 04, 2006 at 10:41:29AM +0100, Markus Schaber wrote:
> Hi, Charlie,
> Charlie Savage wrote:
> > Hmm, looks like something changed in a header file. I'll take a look at
> > see what's up.
> That seems to be the problem that was discussed here the last days.
> Due to the typedef, the header declarations were wrong. Accidentally,
> there was declared a constant pointer to a Geometry, not a pointer to a
> constant Geometry, in the C-API. See the archives for details.
> Fixing this might break source compatibility for clients, but should
> not break binary compatibility.
> The same problem was triggered in capi/geostest.c and PostGIS.
> HTH,
> Markus
