[geos-devel] GEOS-3.0.0rc2
Charlie Savage cfis at savagexi.com
Sat Nov 4 05:15:54 EST 2006
I'll take a look tomorrow morning.  Sounds like it should be easy to fix.
Charlie
strk at refractions.net wrote:
> Charlie, do you think you can fix this shortly ?
> (otherwise I'd ship rc2 with *known* broken swig bindings)
> --strk;
> On Sat, Nov 04, 2006 at 10:41:29AM +0100, Markus Schaber wrote:
>> Hi, Charlie,
>> Charlie Savage wrote:
>>> Hmm, looks like something changed in a header file.  I'll take a look at
>>> see what's up.
>> That seems to be the problem that was discussed here the last days.
>> Due to the typedef, the header declarations were wrong. Accidentally,
>> there was declared a constant pointer to a Geometry, not a pointer to a
>> constant Geometry, in the C-API. See the archives for details.
>> Fixing this might break source compatibility for clients, but should
>> not break binary compatibility.
>> The same problem was triggered in capi/geostest.c and PostGIS.
>> HTH,
>> Markus
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20061104/e5822f61/smime.bin
