[geos-devel] GEOS-3.0.0rc2
Paul Ramsey
pramsey at refractions.net
Sat Nov 4 17:44:26 EST 2006
Fixed
On 4-Nov-06, at 1:13 PM, Charlie Savage wrote:
> Okay - I've got a fix. But I can't check in, SVN seems to have
> gone down?
> Charlie
> strk at refractions.net wrote:
>> Charlie, do you think you can fix this shortly ?
>> (otherwise I'd ship rc2 with *known* broken swig bindings)
>> --strk;
>> On Sat, Nov 04, 2006 at 10:41:29AM +0100, Markus Schaber wrote:
>>> Hi, Charlie,
>>>> Hmm, looks like something changed in a header file. I'll take a
>>>> look at
>>>> see what's up.
>>> That seems to be the problem that was discussed here the last days.
>>> Due to the typedef, the header declarations were wrong.
>>> Accidentally,
>>> there was declared a constant pointer to a Geometry, not a
>>> pointer to a
>>> constant Geometry, in the C-API. See the archives for details.
>>> Fixing this might break source compatibility for clients, but should
>>> not break binary compatibility.
>>> The same problem was triggered in capi/geostest.c and PostGIS.
>>> HTH,
>>> Markus
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
