[geos-devel] GEOS-3.0.0rc2
Charlie Savage
cfis at savagexi.com
Sat Nov 4 19:26:53 EST 2006
Thanks - changed checked in. I will have to do some testing, but
everything compiles now on Linux.
Charlie
Paul Ramsey wrote:
> Fixed
> On 4-Nov-06, at 1:13 PM, Charlie Savage wrote:
>> Okay - I've got a fix. But I can't check in, SVN seems to have gone
>> down?
>> Charlie
>> strk at refractions.net wrote:
>>> Charlie, do you think you can fix this shortly ?
>>> (otherwise I'd ship rc2 with *known* broken swig bindings)
>>> --strk;
>>> On Sat, Nov 04, 2006 at 10:41:29AM +0100, Markus Schaber wrote:
>>>> Hi, Charlie,
>>>>> Hmm, looks like something changed in a header file. I'll take a
>>>>> look at
>>>>> see what's up.
>>>> That seems to be the problem that was discussed here the last days.
>>>> Due to the typedef, the header declarations were wrong. Accidentally,
>>>> there was declared a constant pointer to a Geometry, not a pointer to a
>>>> constant Geometry, in the C-API. See the archives for details.
>>>> Fixing this might break source compatibility for clients, but should
>>>> not break binary compatibility.
>>>> The same problem was triggered in capi/geostest.c and PostGIS.
>>>> HTH,
>>>> Markus
>>> geos-devel mailing list
>>> geos-devel at geos.refractions.net
>>> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20061104/21b650d3/smime.bin
