[geos-devel] GEOS-3.0.0rc2
Paul Ramsey pramsey at refractions.net
Sun Nov 5 10:47:55 EST 2006
On OS/X 10.4.8, Intel, builds and passes make check, though
robustness tests and many buffer tests fail.
paul-ramseys-computer:~/Code/geos-svn/tests/xmltester pramsey$ ./
XMLTester robustness.xml
Computed snap tolerance: 0.000463
Files: 1
Tests: 4
Failed: 4
Succeeded: 0
On 5-Nov-06, at 7:16 AM, Michael Fuhr wrote:
> On Sat, Nov 04, 2006 at 05:26:53PM -0700, Charlie Savage wrote:
>> Thanks - changed checked in.  I will have to do some testing, but
>> everything compiles now on Linux.
> The build succeeded and passed all regression tests on FreeBSD
> 6.2-PRERELEASE i386 and Solaris 9/sparc 32-bit, both using
> --enable-python --enable-ruby.  Solaris 9/sparc 64-bit also built
> and passed all tests, although I didn't configure that build with
> the Python and Ruby bindings.
> After installing GEOS I built and tested the latest PostGIS on the
> above platforms.  All tests passed on all platforms.
> Michael Fuhr
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
