[geos-devel] GEOS-3.0.0rc2
strk at refractions.net
Sun Nov 5 10:52:38 EST 2006
Those 'robustness.xml' testcases are broken.
They are based on comparison with an 'expected' output, that's
the reason why they are not automatically run by 'make check'.
To really tell wheter it works or not you should *see*
the results.
Try usin the '--sql-output -v' flags to XMLTester and pipe
to psql, then fire-up your preferred GIS client and inspect
the results.
--strk;
On Sun, Nov 05, 2006 at 07:47:55AM -0800, Paul Ramsey wrote:
> On OS/X 10.4.8, Intel, builds and passes make check, though
> robustness tests and many buffer tests fail.
> paul-ramseys-computer:~/Code/geos-svn/tests/xmltester pramsey$ ./
> XMLTester robustness.xml
> Computed snap tolerance: 0.000463
> Files: 1
> Tests: 4
> Failed: 4
> Succeeded: 0
> On 5-Nov-06, at 7:16 AM, Michael Fuhr wrote:
> >On Sat, Nov 04, 2006 at 05:26:53PM -0700, Charlie Savage wrote:
> >>Thanks - changed checked in. I will have to do some testing, but
> >>everything compiles now on Linux.
> >The build succeeded and passed all regression tests on FreeBSD
> >6.2-PRERELEASE i386 and Solaris 9/sparc 32-bit, both using
> >--enable-python --enable-ruby. Solaris 9/sparc 64-bit also built
> >and passed all tests, although I didn't configure that build with
> >the Python and Ruby bindings.
> >After installing GEOS I built and tested the latest PostGIS on the
> >above platforms. All tests passed on all platforms.
> >Michael Fuhr
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
