[geos-devel] Building GEOS 3.0.0 on windows
Mir Hassan Ali
mirhassanali at gmail.com
Fri Nov 10 06:18:53 EST 2006
Hi
I have a small GIS application in C# that uses GDAL library. But now I need
some functionality provided by GEOS, so I need to build GEOS and then
rebuild GDAL with GEOS support. Is there any older version of GEOS that i
can use or perhaps any other way you can think of.
Best Regards
Mir
On 11/10/06, strk at refractions.net <strk at refractions.net> wrote:
> This is a known "problem".
> We knew, and still made the release :)
> Unless some win32 guy steps in and fixes it, will continue to be broken.
> Why are you using window, anyway ? :P
> --strk;
> On Fri, Nov 10, 2006 at 11:00:37AM +0000, Mir Hassan Ali wrote:
> > Hi
> > I am trying to build the latest GEOS using the provided make file on
> Visual
> > Studio .NET 2003. I have downloaded the files from the subversion trunk.
> > When I try to build the project using the nmake command, I get the
> following
> > errors:
> > ..\capi\geos_c.cpp(124) : error C2733: second C linkage of overloaded
> > function '
> > GEOSDisjoint' not allowed
> > ..\capi\geos_c.cpp(123) : see declaration of 'GEOSDisjoint'
> > ..\capi\geos_c.cpp(145) : error C2733: second C linkage of overloaded
> > function '
> > GEOSTouches' not allowed
> > ..\capi\geos_c.cpp(144) : see declaration of 'GEOSTouches'
> > ..\capi\geos_c.cpp(167) : error C2733: second C linkage of overloaded
> > function '
> > GEOSIntersects' not allowed
> > ..\capi\geos_c.cpp(166) : see declaration of 'GEOSIntersects'
> > ..\capi\geos_c.cpp(189) : error C2733: second C linkage of overloaded
> > function '
> > GEOSCrosses' not allowed
> > ..\capi\geos_c.cpp(188) : see declaration of 'GEOSCrosses'
> > ..\capi\geos_c.cpp(211) : error C2733: second C linkage of overloaded
> > function '
> > GEOSWithin' not allowed
> > and a lot of same errors for other functions. Could anyone tell me how
> to
> > remove this problem.
> > Any help will be appreciated.
> > Best Regards
> > Mir Hassan Ali
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
> /"\ ASCII Ribbon Campaign
> \ / Respect for low technology.
> X Keep e-mail messages readable by any computer system.
> / \ Keep it ASCII.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20061110/f46c23f9/attachment.html
