[geos-devel] Building GEOS 3.0.0 on windows
strk at refractions.net strk at refractions.net
Fri Nov 10 06:29:23 EST 2006
On Fri, Nov 10, 2006 at 11:18:53AM +0000, Mir Hassan Ali wrote:
> Hi
> I have a small GIS application in C# that uses GDAL library. But now I need
> some functionality provided by GEOS, so I need to build GEOS and then
> rebuild GDAL with GEOS support. Is there any older version of GEOS that i
> can use or perhaps any other way you can think of.
The easiest way is just fix the geos_c.h.vc, probably.
is that what you use for building ?
--strk
