[geos-devel] Building GEOS 3.0.0 on windows
strk at refractions.net strk at refractions.net
Fri Nov 10 12:33:39 EST 2006
What hobu is saying is that's *geos_c.h* is having that out-of-sync
info (or at least this is what I understood)
--strk;
On Fri, Nov 10, 2006 at 09:30:38AM -0800, Paul Ramsey wrote:
> geos_c.h.vc appears to be staticly committed into SVN, hence it is
> not picking up the version information from above.  Editing it to
> have some replacement macros and making it a .in file might be the
> thing.
> P
> On 10-Nov-06, at 7:58 AM, strk at refractions.net wrote:
> >On Fri, Nov 10, 2006 at 09:40:45AM -0600, Howard Butler wrote:
> >>At 09:22 AM 11/10/2006, strk at refractions.net wrote:
> >>>On Fri, Nov 10, 2006 at 09:07:33AM -0600, Howard Butler wrote:
> >>>>>#define GEOS_VERSION "3.0.0rc1"
> >>>>is version block of geos_c.h after running configure
> >>>Did you run autogen.sh ?
> >>>Version is in configure.ac, then goes to configure, and finally
> >>>goes into the geos_c.h file.
> >>I shouldn't have to because configure, et.al should be rerun and
> >>recommitted after each release, right?
> >Not committed (./configure should NOT be in SVN), but
> >./autogen.sh should be run before 'make dist', which should
> >give you the new version.
> >Paul ? Any idea ?
> >--strk;
