[geos-devel] Building GEOS 3.0.0 on windows
Paul Ramsey pramsey at refractions.net
Fri Nov 10 12:46:36 EST 2006
When I run autogen.sh I get the right versions into configure.  When
I run configure I get the right versions into the .h and (now) .h.vc
files.
On 10-Nov-06, at 7:58 AM, strk at refractions.net wrote:
> On Fri, Nov 10, 2006 at 09:40:45AM -0600, Howard Butler wrote:
>> At 09:22 AM 11/10/2006, strk at refractions.net wrote:
>>> On Fri, Nov 10, 2006 at 09:07:33AM -0600, Howard Butler wrote:
>>>>> #define GEOS_VERSION "3.0.0rc1"
>>>> is version block of geos_c.h after running configure
>>> Did you run autogen.sh ?
>>> Version is in configure.ac, then goes to configure, and finally
>>> goes into the geos_c.h file.
>> I shouldn't have to because configure, et.al should be rerun and
>> recommitted after each release, right?
> Not committed (./configure should NOT be in SVN), but
> ./autogen.sh should be run before 'make dist', which should
> give you the new version.
> Paul ? Any idea ?
> --strk;
