[geos-devel] Building GEOS 3.0.0 on windows
strk at refractions.net
Fri Nov 10 12:51:55 EST 2006
On Fri, Nov 10, 2006 at 09:46:36AM -0800, Paul Ramsey wrote:
> When I run autogen.sh I get the right versions into configure. When
> I run configure I get the right versions into the .h and (now) .h.vc
> files.
.h.vc files are not automatically generated, if you get correct versions
there that's due to hobu commits. Since we need to run ./autogen.sh and
./configure to use the 'make dist' rule I guess having the .h.vc files
created by ./configure (or a dist-hook) is a viable solution.
Win32 volunteers ? (no, don't need to make a batch command, just a shell
script)
--strk;
