[geos-devel] Building GEOS with GDAL
Wed Nov 15 09:43:07 EST 2006
strk at refractions.net wrote:
> On Tue, Nov 14, 2006 at 10:06:33AM -0500, Frank Warmerdam wrote:
>>> Can you try ?
>> Strk,
>> That is correct.  The GEOS_DLL specifier has to appear after the main
>> return type, but before pointer modifiers.
> Sorry, I don't understand, which one is correct ?
> 1: extern char GEOS_DLL *GEOSGeomToWKT(const GEOSGeometry* g);
> 2: extern char * GEOS_DLL GEOSGeomToWKT(const GEOSGeometry* g);
Strk,
Option (1) is correct.
> And what if a pointer is 'const':
> 1: extern const char GEOS_DLL *GEOSversion();
> 2: extern char GEOS_DLL const * GEOSversion();
> 3: extern const char GEOS_DLL * GEOSversion();
Option (3) would be correct.  Possibly (2) as well, but I'm not sure
and would encourage you to avoid that form if you aren't prepared to test it.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
