[geos-devel] Building GEOS with GDAL
strk at refractions.net
Wed Nov 15 12:18:33 EST 2006
On Wed, Nov 15, 2006 at 12:59:32PM -0500, Frank Warmerdam wrote:
> OK, I have pulled GEOS from SVN (with strk's fixes for GEOS_DLL positioning)
> and built it and thinks worked just fine, including with GDAL. With the
Cool.
> following caveat...
> The geos_c.h.vc.in in SVN should be removed. It is out of sync with
I agree.
> It does still really suck that I have to configure geos on unix just to
> get a geos_c.h.vc (which I copied from the geos_c.h produced on unix).
> Hopefully the rules for producing the packaged source tarballs (as opposed
> to pulling from SVN) will produce geos_c.h.vc for distribution?
What about just distributing geos_c.h directly ?
It would be re-generated by ./configure but since ./configure
will be run on the distributing host we can as well add it
to the distribution
--strk;
