[geos-devel] geos Help
Elavazhagan.M
elavazhagan.mouniandy at kcubeconsulting.com
Tue Nov 28 01:38:42 EST 2006
Thanks Frank and Mateusz.
Mateusz,
I downloaded the MSVS 2005 solution files from the website you mentioned and
used the files 'version.h' and 'platform.h' from the same website. I renamed
'capi\geos_c.h.in' to 'capi\geos_c.h' and then I copied some of the missing
files (for e.g. 'acconfig.h', 'config.h' and some '.cpp' files) from other
versions of 'geos' and compiled. But I am still stuck with those errors I
mentioned earlier. Please find the MSVS 'build report' with this mail for
details.
Are there any specific settings I need to make before building 'geos'? Or do
I need to refer any 'lib' files in the project?
Kindly help me out.
Rgards,
Ela.
-----Original Message-----
[mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of Mateusz Loskot
Sent: Tuesday, November 28, 2006 10:10 AM
To: GEOS Development List
Subject: Re: [geos-devel] geos Help
Frank Warmerdam wrote:
> Elavazhagan.M wrote:
>> Hi All,
>> I am currently developing a GDAL/OGR Driver for LAS files
>> and I need to use the GEOS library for spatial indexing support. I am
>> using MS Visual Studio 2005 as the developing environment. I
>> downloaded the *geos-svn.tar.bz2* file* *from "*geos.refractions.net*"
>> and changed *geos_c.h.in* to *geos_c.h* and *version.h.in* to
>> *version.h. *When I built GEOS, I am getting the following error in
>> geos_c.h, while other files build successfully.
>> *error C2059: syntax error : '__declspec(dllexport)'
>> d:\geos\capi\geos_c.h*
>> Kindly help me out in resolving this issue. Are there any major
>> changes when I build GEOS with MS Visual Studio?
> Elavazhagan,
> For reasons not clear to me the gdal-svn.tar.bz2 is aparently not being
> updated. Could you try it with the geos-3.0.0rc2 code from the geos page
> instead? I believe I have had good luck with it on windows.
Elavazhagan,
Also, current SVN checkout compiles for me with Visual C++ 2005.
By the way, here you can find my Visual C++ 2005 project files to
compile GEOS:
http://mateusz.loskot.net/projects/geos/
see first bullet under GEOS 3.0.0.
Download it, check README file, put sources into 'geos' directory and it
should work.
Cheers
Mateusz Loskot
geos-devel mailing list
geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.14.19/555 - Release Date: 11/27/2006
1>------ Rebuild All started: Project: geos_lib, Configuration: Debug Win32 ------
1>Deleting intermediate and output files for project 'geos_lib', configuration 'Debug|Win32'
1>Compiling...
1>inlines.cpp
1>CentroidArea.cpp
1>d:\geos\geos\source\algorithm\centroidarea.cpp(45) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\algorithm\centroidarea.cpp(97) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\algorithm\centroidarea.cpp(108) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>CentroidLine.cpp
1>d:\geos\geos\source\algorithm\centroidline.cpp(47) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\algorithm\centroidline.cpp(57) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>CentroidPoint.cpp
1>d:\geos\geos\source\algorithm\centroidpoint.cpp(39) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>CGAlgorithms.cpp
1>d:\geos\geos\source\algorithm\cgalgorithms.cpp(182) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\algorithm\cgalgorithms.cpp(190) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\algorithm\cgalgorithms.cpp(196) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
1>ConvexHull.cpp
1>d:\geos\geos\source\headers\geos\geom\coordinatefilter.h(52) : warning C4100: 'coord' : unreferenced formal parameter
1>d:\geos\geos\source\headers\geos\geom\coordinatefilter.h(59) : warning C4100: 'coord' : unreferenced formal parameter
1>d:\geos\geos\source\headers\geos\util\uniquecoordinatearrayfilter.h(74) : warning C4512: 'geos::util::UniqueCoordinateArrayFilter' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\util\uniquecoordinatearrayfilter.h(37) : see declaration of 'geos::util::UniqueCoordinateArrayFilter'
1>HCoordinate.cpp
1>d:\geos\geos\source\algorithm\hcoordinate.cpp(195) : warning C4244: 'argument' : conversion from 'long double' to 'double', possible loss of data
1>d:\geos\geos\source\algorithm\hcoordinate.cpp(209) : warning C4244: 'argument' : conversion from 'long double' to 'double', possible loss of data
1>d:\geos\geos\source\algorithm\hcoordinate.cpp(220) : warning C4244: 'argument' : conversion from 'long double' to 'double', possible loss of data
1>InteriorPointArea.cpp
1>d:\geos\geos\source\algorithm\interiorpointarea.cpp(81) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\algorithm\interiorpointarea.cpp(127) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>InteriorPointLine.cpp
1>d:\geos\geos\source\algorithm\interiorpointline.cpp(76) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\algorithm\interiorpointline.cpp(85) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\algorithm\interiorpointline.cpp(111) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>InteriorPointPoint.cpp
1>d:\geos\geos\source\algorithm\interiorpointpoint.cpp(58) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>LineIntersector.cpp
1>MCPointInRing.cpp
1>MinimumDiameter.cpp
1>d:\geos\geos\source\algorithm\minimumdiameter.cpp(228) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>NotRepresentableException.cpp
1>PointLocator.cpp
1>d:\geos\geos\source\headers\geos\geomgraph\node.h(136) : warning C4100: 'im' : unreferenced formal parameter
1>d:\geos\geos\source\headers\geos\geomgraph\nodemap.h(100) : warning C4512: 'geos::geomgraph::NodeMap' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\geomgraph\nodemap.h(42) : see declaration of 'geos::geomgraph::NodeMap'
1>d:\geos\geos\source\algorithm\pointlocator.cpp(76) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\algorithm\pointlocator.cpp(84) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>RobustDeterminant.cpp
1>d:\geos\geos\source\algorithm\robustdeterminant.cpp(185) : warning C4127: conditional expression is constant
1>SimplePointInAreaLocator.cpp
1>SimplePointInRing.cpp
1>SIRtreePointInRing.cpp
1>d:\geos\geos\source\algorithm\sirtreepointinring.cpp(52) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>Bintree.cpp
1>d:\geos\geos\source\headers\geos\index\bintree\root.h(62) : warning C4100: 'interval' : unreferenced formal parameter
1>Generating Code...
1>Compiling...
1>Interval.cpp
1>Key.cpp
1>NodeBase.cpp
1>Root.cpp
1>MonotoneChain.cpp
1>d:\geos\geos\source\headers\geos\index\chain\monotonechainoverlapaction.h(71) : warning C4100: 'newSeg2' : unreferenced formal parameter
1>d:\geos\geos\source\headers\geos\index\chain\monotonechainoverlapaction.h(70) : warning C4100: 'newSeg1' : unreferenced formal parameter
1>MonotoneChainBuilder.cpp
1>d:\geos\geos\source\index\chain\monotonechainbuilder.cpp(85) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\index\chain\monotonechainbuilder.cpp(104) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>MonotoneChainOverlapAction.cpp
1>MonotoneChainSelectAction.cpp
1>DoubleBits.cpp
1>IntervalSize.cpp
1>Quadtree.cpp
1>AbstractNode.cpp
1>AbstractSTRtree.cpp
1>ItemBoundable.cpp
1>SIRtree.cpp
1>d:\geos\geos\source\index\strtree\sirtree.cpp(115) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>STRtree.cpp
1>d:\geos\geos\source\index\strtree\strtree.cpp(178) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\index\strtree\strtree.cpp(194) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>SweepLineIndex.cpp
1>d:\geos\geos\source\index\sweepline\sweeplineindex.cpp(62) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\index\sweepline\sweeplineindex.cpp(77) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>SweepLineInterval.cpp
1>Coordinate.cpp
1>CoordinateArraySequence.cpp
1>d:\geos\geos\source\index\quadtree\doublebits.cpp(172) : warning C4702: unreachable code
1>Compiling...
1>CoordinateArraySequenceFactory.cpp
1>CoordinateSequence.cpp
1>d:\geos\geos\source\geom\coordinatesequence.cpp(41) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(73) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(86) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(99) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(117) : warning C4267: 'return' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(131) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(147) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(188) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(212) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\coordinatesequence.cpp(249) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>CoordinateSequenceFactory.cpp
1>Dimension.cpp
1>Envelope.cpp
1>Geometry.cpp
1>d:\geos\geos\source\headers\geos\operation\predicate\rectanglecontains.h(83) : warning C4512: 'geos::operation::predicate::RectangleContains' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\predicate\rectanglecontains.h(47) : see declaration of 'geos::operation::predicate::RectangleContains'
1>d:\geos\geos\source\headers\geos\operation\predicate\rectangleintersects.h(82) : warning C4512: 'geos::operation::predicate::RectangleIntersects' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\predicate\rectangleintersects.h(43) : see declaration of 'geos::operation::predicate::RectangleIntersects'
1>d:\geos\geos\source\headers\geos\operation\relate\relatecomputer.h(102) : warning C4512: 'geos::operation::relate::RelateComputer' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\relate\relatecomputer.h(62) : see declaration of 'geos::operation::relate::RelateComputer'
1>d:\geos\geos\source\headers\geos\operation\relate\relateop.h(61) : warning C4512: 'geos::operation::relate::RelateOp' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\relate\relateop.h(43) : see declaration of 'geos::operation::relate::RelateOp'
1>GeometryCollection.cpp
1>GeometryComponentFilter.cpp
1>d:\geos\geos\source\geom\geometrycomponentfilter.cpp(29) : warning C4100: 'geom' : unreferenced formal parameter
1>GeometryFactory.cpp
1>GeometryList.cpp
1>IntersectionMatrix.cpp
1>d:\geos\geos\source\geom\intersectionmatrix.cpp(166) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\intersectionmatrix.cpp(167) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\intersectionmatrix.cpp(206) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\intersectionmatrix.cpp(207) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>LinearRing.cpp
1>LineSegment.cpp
1>LineString.cpp
1>d:\geos\geos\source\geom\linestring.cpp(190) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\linestring.cpp(232) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\linestring.cpp(259) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\linestring.cpp(326) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\linestring.cpp(345) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geom\linestring.cpp(346) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>Location.cpp
1>MultiLineString.cpp
1>MultiPoint.cpp
1>MultiPolygon.cpp
1>Point.cpp
1>Polygon.cpp
1>d:\geos\geos\source\geom\geometrycollection.cpp(158) : warning C4702: unreachable code
1>d:\geos\geos\source\geom\geometrycollection.cpp(165) : warning C4702: unreachable code
1>d:\geos\geos\source\geom\geometry.cpp(553) : warning C4706: assignment within conditional expression
1>d:\geos\geos\source\geom\geometry.cpp(562) : warning C4706: assignment within conditional expression
1>Compiling...
1>PrecisionModel.cpp
1>d:\geos\geos\source\geom\precisionmodel.cpp(107) : warning C4100: 'newOffsetY' : unreferenced formal parameter
1>d:\geos\geos\source\geom\precisionmodel.cpp(107) : warning C4100: 'newOffsetX' : unreferenced formal parameter
1>Triangle.cpp
1>CoordinateOperation.cpp
1>GeometryEditor.cpp
1>d:\geos\geos\source\geom\util\geometryeditor.cpp(138) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>GeometryTransformer.cpp
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(114) : warning C4100: 'parent' : unreferenced formal parameter
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(127) : warning C4100: 'parent' : unreferenced formal parameter
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(152) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(143) : warning C4100: 'parent' : unreferenced formal parameter
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(183) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(173) : warning C4100: 'parent' : unreferenced formal parameter
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(198) : warning C4100: 'parent' : unreferenced formal parameter
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(222) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(213) : warning C4100: 'parent' : unreferenced formal parameter
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(265) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(243) : warning C4100: 'parent' : unreferenced formal parameter
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(324) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(315) : warning C4100: 'parent' : unreferenced formal parameter
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(354) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\geom\util\geometrytransformer.cpp(345) : warning C4100: 'parent' : unreferenced formal parameter
1>LinearComponentExtracter.cpp
1>d:\geos\geos\source\headers\geos\geom\util\linearcomponentextracter.h(75) : warning C4512: 'geos::geom::util::LinearComponentExtracter' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\geom\util\linearcomponentextracter.h(34) : see declaration of 'geos::geom::util::LinearComponentExtracter'
1>d:\geos\geos\source\headers\geos\geom\util\pointextracter.h(71) : warning C4512: 'geos::geom::util::PointExtracter' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\geom\util\pointextracter.h(32) : see declaration of 'geos::geom::util::PointExtracter'
1>d:\geos\geos\source\headers\geos\geom\util\polygonextracter.h(78) : warning C4512: 'geos::geom::util::PolygonExtracter' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\geom\util\polygonextracter.h(32) : see declaration of 'geos::geom::util::PolygonExtracter'
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(46) : error C2143: syntax error : missing ';' before '<'
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(46) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(46) : error C2653: 'LinearComponentExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(46) : error C2143: syntax error : missing ';' before '{'
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(46) : error C2447: '{' : missing function header (old-style formal list?)
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(56) : error C2653: 'LinearComponentExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(56) : error C2065: 'Geometry' : undeclared identifier
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(56) : error C2059: syntax error : '>'
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(56) : error C2143: syntax error : missing ';' before '{'
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(56) : error C2447: '{' : missing function header (old-style formal list?)
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(60) : error C2653: 'LinearComponentExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(60) : error C2882: 'geom' : illegal use of namespace identifier in expression
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(60) : error C2448: 'filter_rw' : function-style initializer appears to be a function definition
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(64) : error C2653: 'LinearComponentExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(64) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(64) : error C2143: syntax error : missing ',' before '*'
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(65) : error C2882: 'geom' : illegal use of namespace identifier in expression
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(65) : error C2065: 'LineString' : undeclared identifier
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(65) : error C2065: 'LinearRing' : undeclared identifier
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(65) : error C2065: 'comps' : undeclared identifier
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(65) : error C2227: left of '->push_back' must point to class/struct/union/generic type
1> type is ''unknown-type''
1>d:\geos\geos\source\geom\util\linearcomponentextracter.cpp(65) : error C2059: syntax error : ')'
1>PointExtracter.cpp
1>d:\geos\geos\source\geom\util\pointextracter.cpp(46) : error C2143: syntax error : missing ';' before '<'
1>d:\geos\geos\source\geom\util\pointextracter.cpp(46) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\geom\util\pointextracter.cpp(46) : error C2653: 'PointExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\pointextracter.cpp(46) : error C2143: syntax error : missing ';' before '{'
1>d:\geos\geos\source\geom\util\pointextracter.cpp(46) : error C2447: '{' : missing function header (old-style formal list?)
1>d:\geos\geos\source\geom\util\pointextracter.cpp(56) : error C2653: 'PointExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\pointextracter.cpp(56) : error C2065: 'Geometry' : undeclared identifier
1>d:\geos\geos\source\geom\util\pointextracter.cpp(56) : error C2059: syntax error : '>'
1>d:\geos\geos\source\geom\util\pointextracter.cpp(56) : error C2143: syntax error : missing ';' before '{'
1>d:\geos\geos\source\geom\util\pointextracter.cpp(56) : error C2447: '{' : missing function header (old-style formal list?)
1>d:\geos\geos\source\geom\util\pointextracter.cpp(61) : error C2653: 'PointExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\pointextracter.cpp(61) : error C2882: 'geom' : illegal use of namespace identifier in expression
1>d:\geos\geos\source\geom\util\pointextracter.cpp(61) : error C2448: 'filter_rw' : function-style initializer appears to be a function definition
1>d:\geos\geos\source\geom\util\pointextracter.cpp(65) : error C2653: 'PointExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\pointextracter.cpp(65) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\geom\util\pointextracter.cpp(65) : error C2143: syntax error : missing ',' before '*'
1>d:\geos\geos\source\geom\util\pointextracter.cpp(66) : error C2882: 'geom' : illegal use of namespace identifier in expression
1>d:\geos\geos\source\geom\util\pointextracter.cpp(66) : error C2065: 'Point' : undeclared identifier
1>d:\geos\geos\source\geom\util\pointextracter.cpp(66) : error C2065: 'comps' : undeclared identifier
1>d:\geos\geos\source\geom\util\pointextracter.cpp(66) : error C2227: left of '->push_back' must point to class/struct/union/generic type
1>d:\geos\geos\source\geom\util\pointextracter.cpp(66) : error C2059: syntax error : ')'
1>PolygonExtracter.cpp
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(43) : error C2143: syntax error : missing ';' before '<'
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(43) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(43) : error C2653: 'PolygonExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(43) : error C2143: syntax error : missing ';' before '{'
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(43) : error C2447: '{' : missing function header (old-style formal list?)
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(53) : error C2653: 'PolygonExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(53) : error C2065: 'Geometry' : undeclared identifier
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(53) : error C2059: syntax error : '>'
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(53) : error C2143: syntax error : missing ';' before '{'
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(53) : error C2447: '{' : missing function header (old-style formal list?)
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(57) : error C2653: 'PolygonExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(57) : error C2882: 'geom' : illegal use of namespace identifier in expression
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(57) : error C2448: 'filter_rw' : function-style initializer appears to be a function definition
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(61) : error C2653: 'PolygonExtracter' : is not a class or namespace name
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(61) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(61) : error C2143: syntax error : missing ',' before '*'
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(62) : error C2882: 'geom' : illegal use of namespace identifier in expression
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(62) : error C2065: 'Polygon' : undeclared identifier
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(62) : error C2065: 'comps' : undeclared identifier
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(62) : error C2227: left of '->push_back' must point to class/struct/union/generic type
1>d:\geos\geos\source\geom\util\polygonextracter.cpp(62) : error C2059: syntax error : ')'
1>ShortCircuitedGeometryVisitor.cpp
1>d:\geos\geos\source\geom\util\shortcircuitedgeometryvisitor.cpp(34) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>Depth.cpp
1>DirectedEdge.cpp
1>d:\geos\geos\source\headers\geos\geomgraph\edge.h(100) : warning C4267: 'return' : conversion from 'size_t' to 'int', possible loss of data
1>DirectedEdgeStar.cpp
1>Edge.cpp
1>d:\geos\geos\source\geomgraph\edge.cpp(82) : warning C4355: 'this' : used in base member initializer list
1>d:\geos\geos\source\geomgraph\edge.cpp(97) : warning C4355: 'this' : used in base member initializer list
1>EdgeEnd.cpp
1>EdgeEndStar.cpp
1>EdgeIntersection.cpp
1>EdgeIntersectionList.cpp
1>EdgeList.cpp
1>d:\geos\geos\source\geomgraph\edgelist.cpp(49) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\geomgraph\edgelist.cpp(80) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\geomgraph\edgelist.cpp(135) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>EdgeNodingValidator.cpp
1>d:\geos\geos\source\headers\geos\noding\nodingvalidator.h(102) : warning C4512: 'geos::noding::NodingValidator' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\nodingvalidator.h(47) : see declaration of 'geos::noding::NodingValidator'
1>d:\geos\geos\source\headers\geos\geomgraph\edgenodingvalidator.h(67) : warning C4512: 'geos::geomgraph::EdgeNodingValidator' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\geomgraph\edgenodingvalidator.h(49) : see declaration of 'geos::geomgraph::EdgeNodingValidator'
1>d:\geos\geos\source\headers\geos\noding\segmentnode.h(94) : warning C4512: 'geos::noding::SegmentNode' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\segmentnode.h(42) : see declaration of 'geos::noding::SegmentNode'
1>d:\geos\geos\source\headers\geos\noding\segmentnodelist.h(176) : warning C4512: 'geos::noding::SegmentNodeList' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\segmentnodelist.h(47) : see declaration of 'geos::noding::SegmentNodeList'
1>d:\geos\geos\source\headers\geos\noding\segmentstring.h(169) : warning C4512: 'geos::noding::SegmentString' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\segmentstring.h(55) : see declaration of 'geos::noding::SegmentString'
1>EdgeRing.cpp
1>Compiling...
1>GeometryGraph.cpp
1>GraphComponent.cpp
1>Label.cpp
1>Node.cpp
1>NodeFactory.cpp
1>NodeMap.cpp
1>PlanarGraph.cpp
1>d:\geos\geos\source\geomgraph\planargraph.cpp(385) : warning C4267: 'argument' : conversion from 'size_t' to 'char', possible loss of data
1>Position.cpp
1>Quadrant.cpp
1>TopologyLocation.cpp
1>MonotoneChainEdge.cpp
1>d:\geos\geos\source\geomgraph\index\monotonechainedge.cpp(105) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>MonotoneChainIndexer.cpp
1>SegmentIntersector.cpp
1>SimpleEdgeSetIntersector.cpp
1>d:\geos\geos\source\geomgraph\index\simpleedgesetintersector.cpp(94) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>SimpleMCSweepLineIntersector.cpp
1>d:\geos\geos\source\geomgraph\index\simplemcsweeplineintersector.cpp(97) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geomgraph\index\simplemcsweeplineintersector.cpp(98) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geomgraph\index\simplemcsweeplineintersector.cpp(100) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geomgraph\index\simplemcsweeplineintersector.cpp(118) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\geomgraph\index\simplemcsweeplineintersector.cpp(133) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>SimpleSweepLineIntersector.cpp
1>d:\geos\geos\source\geomgraph\index\simplesweeplineintersector.cpp(90) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>SweepLineEvent.cpp
1>SweepLineSegment.cpp
1>ByteOrderDataInStream.cpp
1>d:\geos\geos\source\headers\geos\io\byteorderdatainstream.inl(79) : warning C4244: 'return' : conversion from 'int64' to 'long', possible loss of data
1>ByteOrderValues.cpp
1>Compiling...
1>ParseException.cpp
1>StringTokenizer.cpp
1>d:\geos\geos\source\headers\geos\io\stringtokenizer.h(45) : warning C4512: 'geos::io::StringTokenizer' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\io\stringtokenizer.h(25) : see declaration of 'geos::io::StringTokenizer'
1>Unload.cpp
1>WKBReader.cpp
1>d:\geos\geos\source\headers\geos\io\wkbreader.h(150) : warning C4512: 'geos::io::WKBReader' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\io\wkbreader.h(66) : see declaration of 'geos::io::WKBReader'
1>d:\geos\geos\source\io\wkbreader.cpp(465) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>WKBWriter.cpp
1>d:\geos\geos\source\io\wkbwriter.cpp(127) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\io\wkbwriter.cpp(155) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\io\wkbwriter.cpp(205) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>WKTReader.cpp
1>WKTWriter.cpp
1>d:\geos\geos\source\io\wktwriter.cpp(57) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\io\wktwriter.cpp(295) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\io\wktwriter.cpp(329) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\io\wktwriter.cpp(352) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\io\wktwriter.cpp(373) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\io\wktwriter.cpp(398) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>Writer.cpp
1>IntersectionAdder.cpp
1>d:\geos\geos\source\headers\geos\noding\intersectionadder.h(163) : warning C4512: 'geos::noding::IntersectionAdder' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\intersectionadder.h(55) : see declaration of 'geos::noding::IntersectionAdder'
1>IntersectionFinderAdder.cpp
1>d:\geos\geos\source\headers\geos\noding\intersectionfinderadder.h(90) : warning C4512: 'geos::noding::IntersectionFinderAdder' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\intersectionfinderadder.h(50) : see declaration of 'geos::noding::IntersectionFinderAdder'
1>IteratedNoder.cpp
1>d:\geos\geos\source\headers\geos\noding\mcindexnoder.h(100) : warning C4512: 'geos::noding::MCIndexNoder::SegmentOverlapAction' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\mcindexnoder.h(87) : see declaration of 'geos::noding::MCIndexNoder::SegmentOverlapAction'
1>d:\geos\geos\source\headers\geos\noding\mcindexnoder.h(99) : warning C4100: 's2' : unreferenced formal parameter
1>d:\geos\geos\source\headers\geos\noding\mcindexnoder.h(99) : warning C4100: 's1' : unreferenced formal parameter
1>MCIndexNoder.cpp
1>NodingValidator.cpp
1>d:\geos\geos\source\noding\nodingvalidator.cpp(66) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\nodingvalidator.cpp(112) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\nodingvalidator.cpp(113) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\nodingvalidator.cpp(175) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>Octant.cpp
1>d:\geos\geos\source\headers\geos\noding\octant.h(62) : warning C4100: 'p0' : unreferenced formal parameter
1>ScaledNoder.cpp
1>d:\geos\geos\source\headers\geos\noding\scalednoder.h(109) : warning C4512: 'geos::noding::ScaledNoder' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\scalednoder.h(55) : see declaration of 'geos::noding::ScaledNoder'
1>d:\geos\geos\source\headers\geos\noding\scalednoder.h(105) : warning C4100: 'c' : unreferenced formal parameter
1>d:\geos\geos\source\noding\scalednoder.cpp(93) : warning C4512: 'geos::noding::ScaledNoder::Scaler' : assignment operator could not be generated
1> d:\geos\geos\source\noding\scalednoder.cpp(75) : see declaration of 'geos::noding::ScaledNoder::Scaler'
1>d:\geos\geos\source\noding\scalednoder.cpp(112) : warning C4512: 'geos::noding::ScaledNoder::ReScaler' : assignment operator could not be generated
1> d:\geos\geos\source\noding\scalednoder.cpp(95) : see declaration of 'geos::noding::ScaledNoder::ReScaler'
1>d:\geos\geos\source\noding\scalednoder.cpp(107) : warning C4100: 'c' : unreferenced formal parameter
1>SegmentNode.cpp
1>SegmentNodeList.cpp
1>d:\geos\geos\source\noding\segmentnodelist.cpp(74) : warning C4267: 'argument' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\segmentnodelist.cpp(112) : warning C4267: 'argument' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\segmentnodelist.cpp(124) : warning C4267: 'argument' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\segmentnodelist.cpp(126) : warning C4267: 'argument' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\segmentnodelist.cpp(282) : warning C4267: 'argument' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>SegmentString.cpp
1>d:\geos\geos\source\headers\geos\noding\segmentstring.inl(30) : warning C4355: 'this' : used in base member initializer list
1>d:\geos\geos\source\headers\geos\noding\segmentstring.inl(35) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\segmentstring.cpp(55) : warning C4100: 'geomIndex' : unreferenced formal parameter
1>d:\geos\geos\source\noding\segmentstring.cpp(137) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>SimpleNoder.cpp
1>d:\geos\geos\source\noding\simplenoder.cpp(35) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\simplenoder.cpp(36) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>HotPixel.cpp
1>d:\geos\geos\source\headers\geos\noding\snapround\hotpixel.h(155) : warning C4512: 'geos::noding::snapround::HotPixel' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\snapround\hotpixel.h(53) : see declaration of 'geos::noding::snapround::HotPixel'
1>d:\geos\geos\source\io\wktreader.cpp(329) : warning C4702: unreachable code
1>Compiling...
1>MCIndexPointSnapper.cpp
1>d:\geos\geos\source\headers\geos\noding\snapround\mcindexpointsnapper.h(78) : warning C4512: 'geos::noding::snapround::MCIndexPointSnapper' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\snapround\mcindexpointsnapper.h(44) : see declaration of 'geos::noding::snapround::MCIndexPointSnapper'
1>d:\geos\geos\source\headers\geos\noding\snapround\simplesnaprounder.h(142) : warning C4512: 'geos::noding::snapround::SimpleSnapRounder' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\snapround\simplesnaprounder.h(68) : see declaration of 'geos::noding::snapround::SimpleSnapRounder'
1>d:\geos\geos\source\noding\snapround\mcindexpointsnapper.cpp(74) : warning C4512: 'geos::noding::snapround::HotPixelSnapAction' : assignment operator could not be generated
1> d:\geos\geos\source\noding\snapround\mcindexpointsnapper.cpp(38) : see declaration of 'geos::noding::snapround::HotPixelSnapAction'
1>d:\geos\geos\source\noding\snapround\mcindexpointsnapper.cpp(72) : warning C4100: 'ls' : unreferenced formal parameter
1>d:\geos\geos\source\noding\snapround\mcindexpointsnapper.cpp(95) : warning C4512: 'geos::noding::snapround::MCIndexPointSnapperVisitor' : assignment operator could not be generated
1> d:\geos\geos\source\noding\snapround\mcindexpointsnapper.cpp(76) : see declaration of 'geos::noding::snapround::MCIndexPointSnapperVisitor'
1>MCIndexSnapRounder.cpp
1>d:\geos\geos\source\headers\geos\noding\snapround\mcindexsnaprounder.h(132) : warning C4512: 'geos::noding::snapround::MCIndexSnapRounder' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\noding\snapround\mcindexsnaprounder.h(73) : see declaration of 'geos::noding::snapround::MCIndexSnapRounder'
1>d:\geos\geos\source\noding\snapround\mcindexsnaprounder.cpp(77) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>SimpleSnapRounder.cpp
1>d:\geos\geos\source\noding\snapround\simplesnaprounder.cpp(152) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\noding\snapround\simplesnaprounder.cpp(157) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>Subgraph.cpp
1>d:\geos\geos\source\headers\geos\planargraph\subgraph.h(139) : warning C4512: 'geos::planargraph::Subgraph' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\planargraph\subgraph.h(49) : see declaration of 'geos::planargraph::Subgraph'
1>ConnectedSubgraphFinder.cpp
1>d:\geos\geos\source\headers\geos\planargraph\algorithm\connectedsubgraphfinder.h(85) : warning C4512: 'geos::planargraph::algorithm::ConnectedSubgraphFinder' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\planargraph\algorithm\connectedsubgraphfinder.h(44) : see declaration of 'geos::planargraph::algorithm::ConnectedSubgraphFinder'
1>GeometryGraphOperation.cpp
1>IsSimpleOp.cpp
1>d:\geos\geos\source\operation\issimpleop.cpp(68) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>BufferBuilder.cpp
1>d:\geos\geos\source\headers\geos\operation\buffer\offsetcurvesetbuilder.h(184) : warning C4512: 'geos::operation::buffer::OffsetCurveSetBuilder' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\buffer\offsetcurvesetbuilder.h(60) : see declaration of 'geos::operation::buffer::OffsetCurveSetBuilder'
1>BufferOp.cpp
1>BufferSubgraph.cpp
1>d:\geos\geos\source\operation\buffer\buffersubgraph.cpp(52) : warning C4100: 'cga' : unreferenced formal parameter
1>d:\geos\geos\source\operation\buffer\buffersubgraph.cpp(325) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>OffsetCurveBuilder.cpp
1>d:\geos\geos\source\operation\buffer\offsetcurvebuilder.cpp(170) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\buffer\offsetcurvebuilder.cpp(195) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\buffer\offsetcurvebuilder.cpp(213) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\buffer\offsetcurvebuilder.cpp(235) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>OffsetCurveSetBuilder.cpp
1>d:\geos\geos\source\operation\buffer\offsetcurvesetbuilder.cpp(159) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>RightmostEdgeFinder.cpp
1>SubgraphDepthLocater.cpp
1>d:\geos\geos\source\operation\buffer\subgraphdepthlocater.cpp(129) : warning C4512: 'geos::operation::buffer::DepthSegment' : assignment operator could not be generated
1> d:\geos\geos\source\operation\buffer\subgraphdepthlocater.cpp(54) : see declaration of 'geos::operation::buffer::DepthSegment'
1>d:\geos\geos\source\operation\buffer\subgraphdepthlocater.cpp(233) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>ConnectedElementLocationFilter.cpp
1>ConnectedElementPointFilter.cpp
1>DistanceOp.cpp
1>d:\geos\geos\source\operation\distance\distanceop.cpp(416) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\distance\distanceop.cpp(417) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\distance\distanceop.cpp(458) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>GeometryLocation.cpp
1>EdgeSetNoder.cpp
1>ElevationMatrix.cpp
1>d:\geos\geos\source\headers\geos\operation\overlay\elevationmatrix.h(61) : warning C4512: 'geos::operation::overlay::ElevationMatrixFilter' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\overlay\elevationmatrix.h(51) : see declaration of 'geos::operation::overlay::ElevationMatrixFilter'
1>d:\geos\geos\source\headers\geos\operation\overlay\elevationmatrix.h(90) : warning C4512: 'geos::operation::overlay::ElevationMatrix' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\overlay\elevationmatrix.h(66) : see declaration of 'geos::operation::overlay::ElevationMatrix'
1>d:\geos\geos\source\operation\overlay\elevationmatrix.cpp(85) : warning C4355: 'this' : used in base member initializer list
1>Compiling...
1>ElevationMatrixCell.cpp
1>FuzzyPointLocator.cpp
1>d:\geos\geos\source\headers\geos\operation\overlay\fuzzypointlocator.h(80) : warning C4512: 'geos::operation::overlay::FuzzyPointLocator' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\overlay\fuzzypointlocator.h(52) : see declaration of 'geos::operation::overlay::FuzzyPointLocator'
1>d:\geos\geos\source\operation\overlay\fuzzypointlocator.cpp(60) : warning C4100: 'geom' : unreferenced formal parameter
1>d:\geos\geos\source\operation\overlay\fuzzypointlocator.cpp(92) : warning C4100: 'geom' : unreferenced formal parameter
1>LineBuilder.cpp
1>d:\geos\geos\source\operation\overlay\linebuilder.cpp(212) : warning C4267: 'argument' : conversion from 'size_t' to 'const int', possible loss of data
1>d:\geos\geos\source\operation\overlay\linebuilder.cpp(246) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\overlay\linebuilder.cpp(254) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>MaximalEdgeRing.cpp
1>MinimalEdgeRing.cpp
1>OffsetPointGenerator.cpp
1>d:\geos\geos\source\headers\geos\operation\overlay\offsetpointgenerator.h(64) : warning C4512: 'geos::operation::overlay::OffsetPointGenerator' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\overlay\offsetpointgenerator.h(43) : see declaration of 'geos::operation::overlay::OffsetPointGenerator'
1>OverlayNodeFactory.cpp
1>OverlayOp.cpp
1>d:\geos\geos\source\headers\geos\operation\overlay\overlayresultvalidator.h(105) : warning C4512: 'geos::operation::overlay::OverlayResultValidator' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\overlay\overlayresultvalidator.h(54) : see declaration of 'geos::operation::overlay::OverlayResultValidator'
1>d:\geos\geos\source\headers\geos\operation\overlay\pointbuilder.h(77) : warning C4100: 'newPtLocator' : unreferenced formal parameter
1>d:\geos\geos\source\operation\overlay\overlayop.cpp(789) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\overlay\overlayop.cpp(853) : warning C4512: 'geos::operation::overlay::PointCoveredByAny' : assignment operator could not be generated
1> d:\geos\geos\source\operation\overlay\overlayop.cpp(830) : see declaration of 'geos::operation::overlay::PointCoveredByAny'
1>OverlayResultValidator.cpp
1>PointBuilder.cpp
1>PolygonBuilder.cpp
1>PolygonizeDirectedEdge.cpp
1>PolygonizeEdge.cpp
1>PolygonizeGraph.cpp
1>d:\geos\geos\source\operation\polygonize\polygonizegraph.cpp(368) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>Polygonizer.cpp
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(55) : warning C4355: 'this' : used in base member initializer list
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(77) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(83) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(100) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(118) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(254) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(265) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(282) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\polygonize\polygonizer.cpp(295) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>EdgeEndBuilder.cpp
1>EdgeEndBundle.cpp
1>EdgeEndBundleStar.cpp
1>RelateComputer.cpp
1>RelateNode.cpp
1>Compiling...
1>RelateNodeFactory.cpp
1>RelateNodeGraph.cpp
1>RelateOp.cpp
1>ConnectedInteriorTester.cpp
1>d:\geos\geos\source\headers\geos\operation\valid\connectedinteriortester.h(121) : warning C4512: 'geos::operation::valid::ConnectedInteriorTester' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\operation\valid\connectedinteriortester.h(60) : see declaration of 'geos::operation::valid::ConnectedInteriorTester'
1>ConsistentAreaTester.cpp
1>IsValidOp.cpp
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(68) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(211) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(264) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(366) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(403) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(428) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(477) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(557) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(578) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(596) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>QuadtreeNestedRingTester.cpp
1>RepeatedPointTester.cpp
1>d:\geos\geos\source\operation\valid\repeatedpointtester.cpp(64) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\valid\repeatedpointtester.cpp(96) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\valid\repeatedpointtester.cpp(107) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\valid\repeatedpointtester.cpp(118) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>SimpleNestedRingTester.cpp
1>SweeplineNestedRingTester.cpp
1>TopologyValidationError.cpp
1>EdgeString.cpp
1>LineMergeDirectedEdge.cpp
1>LineMergeEdge.cpp
1>LineMergeGraph.cpp
1>LineMerger.cpp
1>d:\geos\geos\source\operation\linemerge\linemerger.cpp(104) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>LineSequencer.cpp
1>d:\geos\geos\source\operation\linemerge\linesequencer.cpp(64) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\linemerge\linesequencer.cpp(72) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\source\operation\linemerge\linesequencer.cpp(295) : warning C4127: conditional expression is constant
1>RectangleContains.cpp
1>d:\geos\geos\source\operation\predicate\rectanglecontains.cpp(59) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\predicate\rectanglecontains.cpp(95) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>RectangleIntersects.cpp
1>d:\geos\geos\source\operation\predicate\rectangleintersects.cpp(115) : warning C4512: 'geos::operation::predicate::EnvelopeIntersectsVisitor' : assignment operator could not be generated
1> d:\geos\geos\source\operation\predicate\rectangleintersects.cpp(47) : see declaration of 'geos::operation::predicate::EnvelopeIntersectsVisitor'
1>d:\geos\geos\source\operation\predicate\rectangleintersects.cpp(184) : warning C4512: 'geos::operation::predicate::ContainsPointVisitor' : assignment operator could not be generated
1> d:\geos\geos\source\operation\predicate\rectangleintersects.cpp(125) : see declaration of 'geos::operation::predicate::ContainsPointVisitor'
1>d:\geos\geos\source\operation\predicate\rectangleintersects.cpp(256) : warning C4512: 'geos::operation::predicate::LineIntersectsVisitor' : assignment operator could not be generated
1> d:\geos\geos\source\operation\predicate\rectangleintersects.cpp(190) : see declaration of 'geos::operation::predicate::LineIntersectsVisitor'
1>SegmentIntersectionTester.cpp
1>d:\geos\geos\source\operation\predicate\segmentintersectiontester.cpp(51) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\predicate\segmentintersectiontester.cpp(55) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\operation\predicate\rectangleintersects.cpp(141) : warning C4706: assignment within conditional expression
1>d:\geos\geos\source\operation\linemerge\linesequencer.cpp(53) : warning C4706: assignment within conditional expression
1>d:\geos\geos\source\operation\valid\isvalidop.cpp(126) : warning C4706: assignment within conditional expression
1>Compiling...
1>CommonBits.cpp
1>CommonBitsOp.cpp
1>CommonBitsRemover.cpp
1>d:\geos\geos\source\precision\commonbitsremover.cpp(52) : warning C4100: 'coord' : unreferenced formal parameter
1>d:\geos\geos\source\precision\commonbitsremover.cpp(68) : warning C4100: 'coord' : unreferenced formal parameter
1>EnhancedPrecisionOp.cpp
1>d:\geos\geos\source\precision\enhancedprecisionop.cpp(80) : warning C4101: 'ex2' : unreferenced local variable
1>GeometrySnapper.cpp
1>d:\geos\geos\source\headers\geos\precision\geometrysnapper.h(89) : warning C4512: 'geos::precision::GeometrySnapper' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\precision\geometrysnapper.h(44) : see declaration of 'geos::precision::GeometrySnapper'
1>d:\geos\geos\source\headers\geos\precision\linestringsnapper.h(111) : warning C4512: 'geos::precision::LineStringSnapper' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\precision\linestringsnapper.h(47) : see declaration of 'geos::precision::LineStringSnapper'
1>d:\geos\geos\source\precision\geometrysnapper.cpp(88) : warning C4512: 'geos::precision::SnapTransformer' : assignment operator could not be generated
1> d:\geos\geos\source\precision\geometrysnapper.cpp(48) : see declaration of 'geos::precision::SnapTransformer'
1>d:\geos\geos\source\precision\geometrysnapper.cpp(82) : warning C4100: 'parent' : unreferenced formal parameter
1>LineStringSnapper.cpp
1>SimpleGeometryPrecisionReducer.cpp
1>d:\geos\geos\source\precision\simplegeometryprecisionreducer.cpp(60) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>Assert.cpp
1>AssertionFailedException.cpp
1>d:\geos\geos\source\util\assertionfailedexception.cpp(34) : error C2653: 'AssertionFailedException' : is not a class or namespace name
1>d:\geos\geos\source\util\assertionfailedexception.cpp(34) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\util\assertionfailedexception.cpp(35) : error C3861: 'GEOSException': identifier not found
1>d:\geos\geos\source\util\assertionfailedexception.cpp(36) : error C3861: 'setName': identifier not found
1>d:\geos\geos\source\util\assertionfailedexception.cpp(37) : warning C4508: 'geos::AssertionFailedException' : function should return a value; 'void' return type assumed
1>d:\geos\geos\source\util\assertionfailedexception.cpp(38) : error C2653: 'AssertionFailedException' : is not a class or namespace name
1>d:\geos\geos\source\util\assertionfailedexception.cpp(38) : error C2065: 'string' : undeclared identifier
1>d:\geos\geos\source\util\assertionfailedexception.cpp(38) : error C2146: syntax error : missing ')' before identifier 'msg'
1>d:\geos\geos\source\util\assertionfailedexception.cpp(38) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\util\assertionfailedexception.cpp(38) : error C2365: 'geos::AssertionFailedException' : redefinition; previous definition was 'function'
1> d:\geos\geos\source\util\assertionfailedexception.cpp(34) : see declaration of 'geos::AssertionFailedException'
1>d:\geos\geos\source\util\assertionfailedexception.cpp(38) : error C2059: syntax error : ')'
1>d:\geos\geos\source\util\assertionfailedexception.cpp(38) : error C2143: syntax error : missing ';' before '{'
1>d:\geos\geos\source\util\assertionfailedexception.cpp(38) : error C2447: '{' : missing function header (old-style formal list?)
1>d:\geos\geos\source\util\assertionfailedexception.cpp(43) : error C2653: 'AssertionFailedException' : is not a class or namespace name
1>d:\geos\geos\source\util\assertionfailedexception.cpp(43) : fatal error C1903: unable to recover from previous error(s); stopping compilation
1>GeometricShapeFactory.cpp
1>IllegalArgumentException.cpp
1>d:\geos\geos\source\util\illegalargumentexception.cpp(35) : error C2653: 'IllegalArgumentException' : is not a class or namespace name
1>d:\geos\geos\source\util\illegalargumentexception.cpp(35) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\util\illegalargumentexception.cpp(35) : error C2550: 'geos::IllegalArgumentException' : constructor initializer lists are only allowed on constructor definitions
1>d:\geos\geos\source\util\illegalargumentexception.cpp(36) : error C3861: 'setName': identifier not found
1>d:\geos\geos\source\util\illegalargumentexception.cpp(37) : warning C4508: 'geos::IllegalArgumentException' : function should return a value; 'void' return type assumed
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C2653: 'IllegalArgumentException' : is not a class or namespace name
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C2065: 'string' : undeclared identifier
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C2146: syntax error : missing ')' before identifier 'msg'
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C2365: 'geos::IllegalArgumentException' : redefinition; previous definition was 'function'
1> d:\geos\geos\source\util\illegalargumentexception.cpp(35) : see declaration of 'geos::IllegalArgumentException'
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C2550: 'void __cdecl geos::`dynamic initializer for 'IllegalArgumentException''(void)' : constructor initializer lists are only allowed on constructor definitions
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C2059: syntax error : ')'
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C2065: 'msg' : undeclared identifier
1>d:\geos\geos\source\util\illegalargumentexception.cpp(38) : error C2448: 'GEOSException' : function-style initializer appears to be a function definition
1>d:\geos\geos\source\util\illegalargumentexception.cpp(43) : error C2653: 'IllegalArgumentException' : is not a class or namespace name
1>d:\geos\geos\source\util\illegalargumentexception.cpp(43) : fatal error C1903: unable to recover from previous error(s); stopping compilation
1>math.cpp
1>Profiler.cpp
1>UnsupportedOperationException.cpp
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(35) : error C2653: 'UnsupportedOperationException' : is not a class or namespace name
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(35) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(35) : error C2550: 'geos::UnsupportedOperationException' : constructor initializer lists are only allowed on constructor definitions
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(36) : error C3861: 'setName': identifier not found
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(37) : warning C4508: 'geos::UnsupportedOperationException' : function should return a value; 'void' return type assumed
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C2653: 'UnsupportedOperationException' : is not a class or namespace name
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C2065: 'string' : undeclared identifier
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C2146: syntax error : missing ')' before identifier 'msg'
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C2365: 'geos::UnsupportedOperationException' : redefinition; previous definition was 'function'
1> d:\geos\geos\source\util\unsupportedoperationexception.cpp(35) : see declaration of 'geos::UnsupportedOperationException'
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C2550: 'void __cdecl geos::`dynamic initializer for 'UnsupportedOperationException''(void)' : constructor initializer lists are only allowed on constructor definitions
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C2059: syntax error : ')'
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C2065: 'msg' : undeclared identifier
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(38) : error C2448: 'GEOSException' : function-style initializer appears to be a function definition
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(43) : error C2653: 'UnsupportedOperationException' : is not a class or namespace name
1>d:\geos\geos\source\util\unsupportedoperationexception.cpp(43) : fatal error C1903: unable to recover from previous error(s); stopping compilation
1>DouglasPeuckerLineSimplifier.cpp
1>d:\geos\geos\source\headers\geos\simplify\douglaspeuckerlinesimplifier.h(84) : warning C4512: 'geos::simplify::DouglasPeuckerLineSimplifier' : assignment operator could not be generated
1> d:\geos\geos\source\headers\geos\simplify\douglaspeuckerlinesimplifier.h(40) : see declaration of 'geos::simplify::DouglasPeuckerLineSimplifier'
1>DouglasPeuckerSimplifier.cpp
1>d:\geos\geos\source\simplify\douglaspeuckersimplifier.cpp(103) : warning C4100: 'parent' : unreferenced formal parameter
1>LineSegmentIndex.cpp
1>TaggedLineSegment.cpp
1>TaggedLinesSimplifier.cpp
1>TaggedLineString.cpp
1>d:\geos\geos\source\simplify\taggedlinestring.cpp(89) : warning C4267: 'argument' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\source\simplify\taggedlinestring.cpp(179) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>Compiling...
1>TaggedLineStringSimplifier.cpp
1>TopologyPreservingSimplifier.cpp
1>d:\geos\geos\source\simplify\topologypreservingsimplifier.cpp(79) : warning C4512: 'geos::simplify::`anonymous-namespace'::LineStringTransformer' : assignment operator could not be generated
1> d:\geos\geos\source\simplify\topologypreservingsimplifier.cpp(58) : see declaration of 'geos::simplify::`anonymous-namespace'::LineStringTransformer'
1>d:\geos\geos\source\simplify\topologypreservingsimplifier.cpp(211) : warning C4512: 'geos::simplify::`anonymous-namespace'::LineStringMapBuilderFilter' : assignment operator could not be generated
1> d:\geos\geos\source\simplify\topologypreservingsimplifier.cpp(190) : see declaration of 'geos::simplify::`anonymous-namespace'::LineStringMapBuilderFilter'
1>geos_c.cpp
1>d:\geos\geos\capi\geos_c.h(47) : warning C4005: 'GEOS_VERSION_MAJOR' : macro redefinition
1> d:\geos\geos\source\headers\geos\version.h(4) : see previous definition of 'GEOS_VERSION_MAJOR'
1>d:\geos\geos\capi\geos_c.h(48) : warning C4005: 'GEOS_VERSION_MINOR' : macro redefinition
1> d:\geos\geos\source\headers\geos\version.h(5) : see previous definition of 'GEOS_VERSION_MINOR'
1>d:\geos\geos\capi\geos_c.h(49) : warning C4005: 'GEOS_VERSION_PATCH' : macro redefinition
1> d:\geos\geos\source\headers\geos\version.h(6) : see previous definition of 'GEOS_VERSION_PATCH'
1>d:\geos\geos\capi\geos_c.h(50) : warning C4005: 'GEOS_VERSION' : macro redefinition
1> d:\geos\geos\source\headers\geos\version.h(7) : see previous definition of 'GEOS_VERSION'
1>d:\geos\geos\capi\geos_c.h(127) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(144) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(147) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(161) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(167) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(218) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(219) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(220) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(227) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(229) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(232) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(249) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(250) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(251) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(253) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(254) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(255) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(257) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(258) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(259) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(260) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(262) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(264) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(265) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(266) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(331) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(344) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(351) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.h(360) : error C2059: syntax error : '__declspec(dllexport)'
1>d:\geos\geos\capi\geos_c.cpp(1049) : warning C4267: 'return' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\capi\geos_c.cpp(1098) : warning C4267: 'return' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\capi\geos_c.cpp(1119) : warning C4267: 'return' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\capi\geos_c.cpp(1426) : warning C4244: 'return' : conversion from 'int' to 'char', possible loss of data
1>d:\geos\geos\capi\geos_c.cpp(1582) : warning C4267: 'initializing' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\capi\geos_c.cpp(1603) : warning C4267: 'initializing' : conversion from 'size_t' to 'unsigned int', possible loss of data
1>d:\geos\geos\capi\geos_c.cpp(1776) : warning C4267: 'return' : conversion from 'size_t' to 'int', possible loss of data
1>d:\geos\geos\capi\geos_c.cpp(1782) : warning C4267: 'return' : conversion from 'size_t' to 'int', possible loss of data
1>Generating Code...
1>Build log was saved at "file://d:\geos\msvc80\geos_lib\Debug\geos_lib\BuildLog.htm"
1>geos_lib - 138 error(s), 496 warning(s)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
