[geos-devel] geos Help
Mateusz Loskot
mateusz at loskot.net
Tue Nov 28 02:55:10 EST 2006
Elavazhagan,
What version of GEOS are you trying to build now?
Elavazhagan.M wrote:
> I downloaded the MSVS 2005 solution files from the website you mentioned and
> used the files 'version.h' and 'platform.h' from the same website.
These two files are old.
I've just put new versions on my website, please, re-download it.
> I renamed
> 'capi\geos_c.h.in' to 'capi\geos_c.h' and then I copied some of the missing
> files (for e.g. 'acconfig.h', 'config.h' and some '.cpp' files) from other
> versions of 'geos' and compiled. But I am still stuck with those errors I
> mentioned earlier. Please find the MSVS 'build report' with this mail for
> details.
> Are there any specific settings I need to make before building 'geos'?
> Or do I need to refer any 'lib' files in the project?
Hmm, what config.h file you mean?
There is no such file GEOS that's required for Visual C++ compiler.
Also, please, don't copy any files across GEOS versions.
OK, I checked my project file and updated it.
Please, download it again from the same location, direct link is:
http://mateusz.loskot.net/download/projects/geos/geos-msvc-2005-project.zip
There are 3 projects:
- DLL with GEOS C API
- Static library with both: C and C++ APIs
- Unit Test runner
Run Rebuild and you should get both libraries compiled and next unit
tests should compile and link and run all tests automatically as
post-build event, so after all you should see tests results in the
output window.
NOTE: I build sources checkouted from GEOS SVN:
svn checkout http://svn.refractions.net/geos/trunk geos
Give me a note if it works for you.
Cheers
Mateusz Loskot
