[geos-devel] C-API Header diversion
strk at refractions.net
Fri Oct 27 06:21:45 EDT 2006
On Fri, Oct 27, 2006 at 11:59:09AM +0200, Markus Schaber wrote:
> Apply the following patch to the .diff file I sent (or correct
> geos_c.h.in manually).
Ok, can you send a full ChangeLog entry for this please ?
> But I get loads of messages like:
> > Trying with original input.
> > Did not run OverlayResultValidator as the precision model is not
> > floating
It is expected, just a debugging message to remind us that overlay
operation are not validated in FIXED precision model...
> Btw, it seems that "make check" does not include any C-API tests...
Right... we should really think about adding some.
I dunno if TUT will be appropriated for this though. Mateusz ?
--strk;
