cmake (was Re: [geos-devel] 3.0?)
Mateusz Loskot
mateusz at loskot.net
Mon Sep 4 02:56:14 EDT 2006
Mateusz Loskot wrote:
> åé«å wrote:
>> # CMakeLists.txt for geos 3.0 by sungaoyong
>> # 2006-09-04 sungaoyong at gmail.com <mailto:sungaoyong at gmail.com>
>> # Building on Cmake 2.4
>> # test on windows mingw32 g++ 3.4.2ãmsvc 2003,linux g++ 4.1
>> # hope it's usefull
> First, I'd like to thank you on behalf of GEOS team for
> this contribution!
> I also run it with success!
> I use Linux (Ubuntu 6.06) + gcc 4.0.3 + cmake 2.4.3 (compiled
> from sources)
> Here are binaries generated by cmake:
> libgeos_i.a
> libgeos.so
> TestSweepLineSpeed
> Is it possible to put CMakeLists.txt file outside the 'source' tree?
> For example, to <GEOS ROOT>/build/cmake
> cmake generates Makefile on the same level as automake, so
> I'd suggest to put cmake outside the tree to avoid potential
> conflicts with autotools (some problems may be unknown at the moment).
> Is this possible to use cmake thisway?
I played for a few minutes with cmake and CMakeLists.txtfile
and I managed to do complete build from outside the sources tree.
I atteched my version of CMakeLists.txt file. Please note, I'm not sure
it's correct, as I'm not a cmake user yet, though it works for me :-)
I copied this file to following location:
<GEOS>/build/cmake/CMakeLists.txt
where <GEOS> is root sources dir of GEOS.
In my environment it's $HOME/dev/geos/_svn/geos/
Now, to build outside the sources tree I run:
$ cd $HOME/dev/geos/_svn/geos/build/cmake
$ cmake .
$ make
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/mloskot/dev/geos/_svn/geos/build/cmake
[ 0%] Building CXX object
CMakeFiles/geos.dir/home/mloskot/dev/geos/_svn/geos/source/inlines.o
[ 99%] Building CXX object
CMakeFiles/geos_i.dir/home/mloskot/dev/geos/_svn/geos-cmake/source/util/math.o
[100%] Building CXX object
CMakeFiles/geos_i.dir/home/mloskot/dev/geos/_svn/geos-cmake/source/util/Profiler.o
Linking CXX static library libgeos_i.a
[100%] Built target geos_i
$ pwd
$ ls
libgeos_i.a
libgeos.so
TestSweepLineSpeed
So, it seems to work.
It may need some more work to tune it but I'd stick to this
approach of "building outside the sources tree".
Cheers
Mateusz Loskot
http://mateusz.loskot.net
# 2006-09-04 mateusz at loskot.net
# Modified to build from outside the source tree (<GEOS>/build/cmake)
# test on windows mingw32 g++ 3.4.2¡¢msvc 2003,linux g++ 4.1
# hope it's usefull
PROJECT(GEOS)
INCLUDE_DIRECTORIES(${CMAKE_SOURCE_DIR}/../../source/headers)
set (JTS_PORT 1.7.1)
set (VERSION_MAJOR 3)
set (VERSION_MINOR 0)
set (VERSION_PATCH 0rc1)
set (VERSION 3.0.0rc1)
INCLUDE(CheckSymbolExists)
#CHECK_SYMBOL_EXISTS(int64_t types.h HAVE_INT64_T_64)
IF(MINGW)
set (HAVE_INT64_T_64 1)
ENDIF(MINGW)
IF(UNIX)
ENDIF(UNIX)
CONFIGURE_FILE(${CMAKE_SOURCE_DIR}/../../source/headers/geos/version.h.in ${CMAKE_SOURCE_DIR}/../../source/headers/geos/version.h)
CONFIGURE_FILE(${CMAKE_SOURCE_DIR}/../../source/headers/geos/platform.h.in.cmake ${CMAKE_SOURCE_DIR}/../../source/headers/geos/platform.h ESCAPE_QUOTES)
#ADD_LIBRARY(geos STATIC inlines.cpp)
#ADD_LIBRARY(geos inlines.cpp)
SET(GEOS_SRCS Hello.c File2.c File3.c)
#ADD_LIBRARY(geos SHARED inlines.cpp
SET(GEOS_SRCS ${CMAKE_SOURCE_DIR}/../../source/inlines.cpp
${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidArea.cpp
${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidLine
${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidPoint
${CMAKE_SOURCE_DIR}/../../source/algorithm/CGAlgorithms
${CMAKE_SOURCE_DIR}/../../source/algorithm/ConvexHull
${CMAKE_SOURCE_DIR}/../../source/algorithm/HCoordinate
${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointArea
${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointLine
${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointPoint
${CMAKE_SOURCE_DIR}/../../source/algorithm/LineIntersector
${CMAKE_SOURCE_DIR}/../../source/algorithm/MCPointInRing
${CMAKE_SOURCE_DIR}/../../source/algorithm/MinimumDiameter
${CMAKE_SOURCE_DIR}/../../source/algorithm/NotRepresentableException
${CMAKE_SOURCE_DIR}/../../source/algorithm/PointLocator
${CMAKE_SOURCE_DIR}/../../source/algorithm/RobustDeterminant
${CMAKE_SOURCE_DIR}/../../source/algorithm/SimplePointInAreaLocator
${CMAKE_SOURCE_DIR}/../../source/algorithm/SimplePointInRing
${CMAKE_SOURCE_DIR}/../../source/algorithm/SIRtreePointInRing
${CMAKE_SOURCE_DIR}/../../source/geom/Coordinate
${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateArraySequence
${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateArraySequenceFactory
${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateSequence
# ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateSequenceFactory
${CMAKE_SOURCE_DIR}/../../source/geom/Dimension
${CMAKE_SOURCE_DIR}/../../source/geom/Envelope
${CMAKE_SOURCE_DIR}/../../source/geom/Geometry
${CMAKE_SOURCE_DIR}/../../source/geom/GeometryCollection
${CMAKE_SOURCE_DIR}/../../source/geom/GeometryComponentFilter
${CMAKE_SOURCE_DIR}/../../source/geom/GeometryFactory
${CMAKE_SOURCE_DIR}/../../source/geom/IntersectionMatrix
${CMAKE_SOURCE_DIR}/../../source/geom/LinearRing
${CMAKE_SOURCE_DIR}/../../source/geom/LineSegment
${CMAKE_SOURCE_DIR}/../../source/geom/LineString
${CMAKE_SOURCE_DIR}/../../source/geom/Location
${CMAKE_SOURCE_DIR}/../../source/geom/MultiLineString
${CMAKE_SOURCE_DIR}/../../source/geom/MultiPoint
${CMAKE_SOURCE_DIR}/../../source/geom/MultiPolygon
${CMAKE_SOURCE_DIR}/../../source/geom/Point
${CMAKE_SOURCE_DIR}/../../source/geom/Polygon
${CMAKE_SOURCE_DIR}/../../source/geom/PrecisionModel
${CMAKE_SOURCE_DIR}/../../source/geom/Triangle
${CMAKE_SOURCE_DIR}/../../source/geom/util/CoordinateOperation
${CMAKE_SOURCE_DIR}/../../source/geom/util/GeometryEditor
${CMAKE_SOURCE_DIR}/../../source/geom/util/GeometryTransformer
# ${CMAKE_SOURCE_DIR}/../../source/geom/util/LinearComponentExtracter
# ${CMAKE_SOURCE_DIR}/../../source/geom/util/PointExtracter
# ${CMAKE_SOURCE_DIR}/../../source/geom/util/PolygonExtracter
${CMAKE_SOURCE_DIR}/../../source/geom/util/ShortCircuitedGeometryVisitor
${CMAKE_SOURCE_DIR}/../../source/geomgraph/Depth
${CMAKE_SOURCE_DIR}/../../source/geomgraph/DirectedEdge
${CMAKE_SOURCE_DIR}/../../source/geomgraph/DirectedEdgeStar
${CMAKE_SOURCE_DIR}/../../source/geomgraph/Edge
${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeEnd
${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeEndStar
${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeIntersection
${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeIntersectionList
${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeList
${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeNodingValidator
${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeRing
${CMAKE_SOURCE_DIR}/../../source/geomgraph/GeometryGraph
${CMAKE_SOURCE_DIR}/../../source/geomgraph/GraphComponent
${CMAKE_SOURCE_DIR}/../../source/geomgraph/Label
${CMAKE_SOURCE_DIR}/../../source/geomgraph/Node
${CMAKE_SOURCE_DIR}/../../source/geomgraph/NodeFactory
${CMAKE_SOURCE_DIR}/../../source/geomgraph/NodeMap
${CMAKE_SOURCE_DIR}/../../source/geomgraph/PlanarGraph
${CMAKE_SOURCE_DIR}/../../source/geomgraph/Position
${CMAKE_SOURCE_DIR}/../../source/geomgraph/Quadrant
${CMAKE_SOURCE_DIR}/../../source/geomgraph/TopologyLocation
${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/MonotoneChainEdge
${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/MonotoneChainIndexer
${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SegmentIntersector
${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleEdgeSetIntersector
${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleMCSweepLineIntersector
${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleSweepLineIntersector
${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SweepLineEvent
${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SweepLineSegment
${CMAKE_SOURCE_DIR}/../../source/index/bintree/Bintree
${CMAKE_SOURCE_DIR}/../../source/index/bintree/Interval
${CMAKE_SOURCE_DIR}/../../source/index/bintree/Key
${CMAKE_SOURCE_DIR}/../../source/index/bintree/Node
${CMAKE_SOURCE_DIR}/../../source/index/bintree/NodeBase
${CMAKE_SOURCE_DIR}/../../source/index/bintree/Root
${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChain
${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainBuilder
${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainOverlapAction
${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainSelectAction
${CMAKE_SOURCE_DIR}/../../source/index/quadtree/DoubleBits
${CMAKE_SOURCE_DIR}/../../source/index/quadtree/IntervalSize
${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Key
${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Node
${CMAKE_SOURCE_DIR}/../../source/index/quadtree/NodeBase
${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Root
${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Quadtree
${CMAKE_SOURCE_DIR}/../../source/index/strtree/AbstractNode
${CMAKE_SOURCE_DIR}/../../source/index/strtree/AbstractSTRtree
${CMAKE_SOURCE_DIR}/../../source/index/strtree/Interval
${CMAKE_SOURCE_DIR}/../../source/index/strtree/ItemBoundable
${CMAKE_SOURCE_DIR}/../../source/index/strtree/SIRtree
${CMAKE_SOURCE_DIR}/../../source/index/strtree/STRtree
${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineEvent
${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineIndex
${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineInterval
${CMAKE_SOURCE_DIR}/../../source/io/ByteOrderDataInStream
${CMAKE_SOURCE_DIR}/../../source/io/ByteOrderValues
${CMAKE_SOURCE_DIR}/../../source/io/ParseException
${CMAKE_SOURCE_DIR}/../../source/io/StringTokenizer
${CMAKE_SOURCE_DIR}/../../source/io/Unload
${CMAKE_SOURCE_DIR}/../../source/io/WKBReader
${CMAKE_SOURCE_DIR}/../../source/io/WKBWriter
${CMAKE_SOURCE_DIR}/../../source/io/WKTReader
${CMAKE_SOURCE_DIR}/../../source/io/WKTWriter
${CMAKE_SOURCE_DIR}/../../source/io/Writer
${CMAKE_SOURCE_DIR}/../../source/noding/IntersectionAdder
${CMAKE_SOURCE_DIR}/../../source/noding/IntersectionFinderAdder
${CMAKE_SOURCE_DIR}/../../source/noding/IteratedNoder
${CMAKE_SOURCE_DIR}/../../source/noding/MCIndexNoder
${CMAKE_SOURCE_DIR}/../../source/noding/NodingValidator
${CMAKE_SOURCE_DIR}/../../source/noding/Octant
${CMAKE_SOURCE_DIR}/../../source/noding/ScaledNoder
${CMAKE_SOURCE_DIR}/../../source/noding/SegmentNode
${CMAKE_SOURCE_DIR}/../../source/noding/SegmentNodeList
${CMAKE_SOURCE_DIR}/../../source/noding/SegmentString
${CMAKE_SOURCE_DIR}/../../source/noding/SimpleNoder
${CMAKE_SOURCE_DIR}/../../source/noding/snapround/HotPixel
${CMAKE_SOURCE_DIR}/../../source/noding/snapround/MCIndexPointSnapper
${CMAKE_SOURCE_DIR}/../../source/noding/snapround/MCIndexSnapRounder
${CMAKE_SOURCE_DIR}/../../source/noding/snapround/SimpleSnapRounder
${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferBuilder
${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferOp
${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferSubgraph
${CMAKE_SOURCE_DIR}/../../source/operation/buffer/OffsetCurveBuilder
${CMAKE_SOURCE_DIR}/../../source/operation/buffer/OffsetCurveSetBuilder
${CMAKE_SOURCE_DIR}/../../source/operation/buffer/RightmostEdgeFinder
${CMAKE_SOURCE_DIR}/../../source/operation/buffer/SubgraphDepthLocater
${CMAKE_SOURCE_DIR}/../../source/operation/distance/ConnectedElementLocationFilter
${CMAKE_SOURCE_DIR}/../../source/operation/distance/ConnectedElementPointFilter
${CMAKE_SOURCE_DIR}/../../source/operation/distance/DistanceOp
${CMAKE_SOURCE_DIR}/../../source/operation/distance/GeometryLocation
${CMAKE_SOURCE_DIR}/../../source/operation/GeometryGraphOperation
${CMAKE_SOURCE_DIR}/../../source/operation/IsSimpleOp
${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/EdgeString
${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeDirectedEdge
${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeEdge
${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeGraph
${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMerger
${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineSequencer
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/EdgeSetNoder
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/ElevationMatrix
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/ElevationMatrixCell
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/LineBuilder
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/MaximalEdgeRing
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/MinimalEdgeRing
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/OverlayNodeFactory
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/OverlayOp
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/PointBuilder
${CMAKE_SOURCE_DIR}/../../source/operation/overlay/PolygonBuilder
${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeDirectedEdge
${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeEdge
${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/EdgeRing
${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeGraph
${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/Polygonizer
${CMAKE_SOURCE_DIR}/../../source/operation/predicate/RectangleContains
${CMAKE_SOURCE_DIR}/../../source/operation/predicate/RectangleIntersects
${CMAKE_SOURCE_DIR}/../../source/operation/predicate/SegmentIntersectionTester
${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBuilder
${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBundle
${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBundleStar
${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateComputer
${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNode
${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNodeFactory
${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNodeGraph
${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateOp
${CMAKE_SOURCE_DIR}/../../source/operation/valid/ConnectedInteriorTester
${CMAKE_SOURCE_DIR}/../../source/operation/valid/ConsistentAreaTester
${CMAKE_SOURCE_DIR}/../../source/operation/valid/IsValidOp
${CMAKE_SOURCE_DIR}/../../source/operation/valid/QuadtreeNestedRingTester
${CMAKE_SOURCE_DIR}/../../source/operation/valid/RepeatedPointTester
${CMAKE_SOURCE_DIR}/../../source/operation/valid/SimpleNestedRingTester
${CMAKE_SOURCE_DIR}/../../source/operation/valid/SweeplineNestedRingTester
${CMAKE_SOURCE_DIR}/../../source/operation/valid/TopologyValidationError
${CMAKE_SOURCE_DIR}/../../source/planargraph/DirectedEdge
${CMAKE_SOURCE_DIR}/../../source/planargraph/DirectedEdgeStar
${CMAKE_SOURCE_DIR}/../../source/planargraph/Edge
${CMAKE_SOURCE_DIR}/../../source/planargraph/Node
${CMAKE_SOURCE_DIR}/../../source/planargraph/NodeMap
${CMAKE_SOURCE_DIR}/../../source/planargraph/PlanarGraph
${CMAKE_SOURCE_DIR}/../../source/planargraph/Subgraph
${CMAKE_SOURCE_DIR}/../../source/planargraph/algorithm/ConnectedSubgraphFinder
${CMAKE_SOURCE_DIR}/../../source/precision/CommonBits
${CMAKE_SOURCE_DIR}/../../source/precision/CommonBitsOp
${CMAKE_SOURCE_DIR}/../../source/precision/CommonBitsRemover
${CMAKE_SOURCE_DIR}/../../source/precision/EnhancedPrecisionOp
${CMAKE_SOURCE_DIR}/../../source/precision/GeometrySnapper
${CMAKE_SOURCE_DIR}/../../source/precision/LineStringSnapper
${CMAKE_SOURCE_DIR}/../../source/precision/SimpleGeometryPrecisionReducer
${CMAKE_SOURCE_DIR}/../../source/simplify/DouglasPeuckerLineSimplifier
${CMAKE_SOURCE_DIR}/../../source/simplify/DouglasPeuckerSimplifier
${CMAKE_SOURCE_DIR}/../../source/simplify/LineSegmentIndex
${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineSegment
${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLinesSimplifier
${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineString
${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineStringSimplifier
${CMAKE_SOURCE_DIR}/../../source/simplify/TopologyPreservingSimplifier
${CMAKE_SOURCE_DIR}/../../source/util/Assert
# ${CMAKE_SOURCE_DIR}/../../source/util/AssertionFailedException
${CMAKE_SOURCE_DIR}/../../source/util/GeometricShapeFactory
# ${CMAKE_SOURCE_DIR}/../../source/util/IllegalArgumentException
${CMAKE_SOURCE_DIR}/../../source/util/math
${CMAKE_SOURCE_DIR}/../../source/util/Profiler
# ${CMAKE_SOURCE_DIR}/../../source/util/UnsupportedOperationException
ADD_LIBRARY(geos SHARED ${GEOS_SRCS})
ADD_LIBRARY(geos_i STATIC ${GEOS_SRCS})
ADD_EXECUTABLE(TestSweepLineSpeed
${CMAKE_SOURCE_DIR}/../../tests/bigtest/GeometryTestFactory
${CMAKE_SOURCE_DIR}/../../tests/bigtest/TestSweepLineSpeed)
TARGET_LINK_LIBRARIES(TestSweepLineSpeed geos)
