cmake (was Re: [geos-devel] 3.0?)
=?GB2312?B?y++439PC?= sungaoyong at gmail.com
Mon Sep 4 03:01:53 EDT 2006
SET(GEOS_SRCS Hello.c File2.c File3.c)
this can delete,this only my test.
On 9/4/06, Mateusz Loskot <mateusz at loskot.net> wrote:
> Mateusz Loskot wrote:
> > 孙高勇 wrote:
> >> #   CMakeLists.txt for geos 3.0 by sungaoyong
> >> #   2006-09-04 sungaoyong at gmail.com <mailto:sungaoyong at gmail.com>
> >> #     Building on Cmake 2.4
> >> #   test on windows mingw32 g++ 3.4.2、msvc 2003,linux g++ 4.1
> >> #   hope it's usefull
> > First, I'd like to thank you on behalf of GEOS team for
> > this contribution!
> > I also run it with success!
> > I use Linux (Ubuntu 6.06) + gcc 4.0.3 + cmake 2.4.3 (compiled
> > from sources)
> > Here are binaries generated by cmake:
> > libgeos_i.a
> > libgeos.so
> > TestSweepLineSpeed
> > Is it possible to put CMakeLists.txt file outside the 'source' tree?
> > For example, to <GEOS ROOT>/build/cmake
> > cmake generates Makefile on the same level as automake, so
> > I'd suggest to put cmake outside the tree to avoid potential
> > conflicts with autotools (some problems may be unknown at the moment).
> > Is this possible to use cmake thisway?
> Hi,
> I played for a few minutes with cmake and CMakeLists.txtfile
> and I managed to do complete build from outside the sources tree.
> I atteched my version of CMakeLists.txt file. Please note, I'm not sure
> it's correct, as I'm not a cmake user yet, though it works for me :-)
> I copied this file to following location:
> <GEOS>/build/cmake/CMakeLists.txt
> where <GEOS> is root sources dir of GEOS.
> In my environment it's $HOME/dev/geos/_svn/geos/
> Now, to build outside the sources tree I run:
> $ cd $HOME/dev/geos/_svn/geos/build/cmake
> $ cmake .
> $ make
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> /home/mloskot/dev/geos/_svn/geos/build/cmake
> [  0%] Building CXX object
> CMakeFiles/geos.dir/home/mloskot/dev/geos/_svn/geos/source/inlines.o
> [ 99%] Building CXX object
> CMakeFiles/geos_i.dir/home/mloskot/dev/geos/_svn/geos-cmake/source/util/math.o
> [100%] Building CXX object
> CMakeFiles/geos_i.dir/home/mloskot/dev/geos/_svn/geos-cmake/source/util/Profiler.o
> Linking CXX static library libgeos_i.a
> [100%] Built target geos_i
> $ pwd
> $ ls
> libgeos_i.a
> libgeos.so
> TestSweepLineSpeed
> So, it seems to work.
> It may need some more work to tune it but I'd stick to this
> approach of "building outside the sources tree".
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> #   2006-09-04 mateusz at loskot.net
> #   Modified to build from outside the source tree (<GEOS>/build/cmake)
> #   test on windows mingw32 g++ 3.4.2¡¢msvc 2003,linux g++ 4.1
> #   hope it's usefull
> PROJECT(GEOS)
> INCLUDE_DIRECTORIES(${CMAKE_SOURCE_DIR}/../../source/headers)
> set (JTS_PORT 1.7.1)
> set (VERSION_MAJOR 3)
> set (VERSION_MINOR 0)
> set (VERSION_PATCH 0rc1)
> set (VERSION 3.0.0rc1)
> INCLUDE(CheckSymbolExists)
> #CHECK_SYMBOL_EXISTS(int64_t types.h HAVE_INT64_T_64)
> IF(MINGW)
>         set (HAVE_INT64_T_64 1)
> ENDIF(MINGW)
> IF(UNIX)
> ENDIF(UNIX)
> CONFIGURE_FILE(${CMAKE_SOURCE_DIR}/../../source/headers/geos/version.h.in
> ${CMAKE_SOURCE_DIR}/../../source/headers/geos/version.h)
> CONFIGURE_FILE(${CMAKE_SOURCE_DIR}/../../source/headers/geos/platform.h.in.cmake
> ${CMAKE_SOURCE_DIR}/../../source/headers/geos/platform.h ESCAPE_QUOTES)
> #ADD_LIBRARY(geos STATIC inlines.cpp)
> #ADD_LIBRARY(geos inlines.cpp)
> #ADD_LIBRARY(geos SHARED  inlines.cpp
> SET(GEOS_SRCS ${CMAKE_SOURCE_DIR}/../../source/inlines.cpp
>     ${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidArea.cpp
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidLine
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidPoint
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/CGAlgorithms
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/ConvexHull
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/HCoordinate
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointArea
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointLine
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointPoint
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/LineIntersector
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/MCPointInRing
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/MinimumDiameter
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/NotRepresentableException
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/PointLocator
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/RobustDeterminant
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/SimplePointInAreaLocator
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/SimplePointInRing
>         ${CMAKE_SOURCE_DIR}/../../source/algorithm/SIRtreePointInRing
>         ${CMAKE_SOURCE_DIR}/../../source/geom/Coordinate
>         ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateArraySequence
>         ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateArraySequenceFactory
>         ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateSequence
> #       ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateSequenceFactory
>         ${CMAKE_SOURCE_DIR}/../../source/geom/Dimension
>         ${CMAKE_SOURCE_DIR}/../../source/geom/Envelope
>         ${CMAKE_SOURCE_DIR}/../../source/geom/Geometry
>         ${CMAKE_SOURCE_DIR}/../../source/geom/GeometryCollection
>         ${CMAKE_SOURCE_DIR}/../../source/geom/GeometryComponentFilter
>         ${CMAKE_SOURCE_DIR}/../../source/geom/GeometryFactory
>         ${CMAKE_SOURCE_DIR}/../../source/geom/IntersectionMatrix
>         ${CMAKE_SOURCE_DIR}/../../source/geom/LinearRing
>         ${CMAKE_SOURCE_DIR}/../../source/geom/LineSegment
>         ${CMAKE_SOURCE_DIR}/../../source/geom/LineString
>         ${CMAKE_SOURCE_DIR}/../../source/geom/Location
>         ${CMAKE_SOURCE_DIR}/../../source/geom/MultiLineString
>         ${CMAKE_SOURCE_DIR}/../../source/geom/MultiPoint
>         ${CMAKE_SOURCE_DIR}/../../source/geom/MultiPolygon
>         ${CMAKE_SOURCE_DIR}/../../source/geom/Point
>         ${CMAKE_SOURCE_DIR}/../../source/geom/Polygon
>         ${CMAKE_SOURCE_DIR}/../../source/geom/PrecisionModel
>         ${CMAKE_SOURCE_DIR}/../../source/geom/Triangle
>         ${CMAKE_SOURCE_DIR}/../../source/geom/util/CoordinateOperation
>         ${CMAKE_SOURCE_DIR}/../../source/geom/util/GeometryEditor
>         ${CMAKE_SOURCE_DIR}/../../source/geom/util/GeometryTransformer
> ${CMAKE_SOURCE_DIR}/../../source/geom/util/LinearComponentExtracter
> #       ${CMAKE_SOURCE_DIR}/../../source/geom/util/PointExtracter
> #       ${CMAKE_SOURCE_DIR}/../../source/geom/util/PolygonExtracter
>         ${CMAKE_SOURCE_DIR}/../../source/geom/util/ShortCircuitedGeometryVisitor
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Depth
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/DirectedEdge
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/DirectedEdgeStar
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Edge
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeEnd
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeEndStar
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeIntersection
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeIntersectionList
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeList
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeNodingValidator
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeRing
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/GeometryGraph
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/GraphComponent
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Label
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Node
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/NodeFactory
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/NodeMap
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/PlanarGraph
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Position
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Quadrant
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/TopologyLocation
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/MonotoneChainEdge
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/MonotoneChainIndexer
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SegmentIntersector
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleEdgeSetIntersector
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleMCSweepLineIntersector
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleSweepLineIntersector
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SweepLineEvent
>         ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SweepLineSegment
>         ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Bintree
>         ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Interval
>         ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Key
>         ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Node
>         ${CMAKE_SOURCE_DIR}/../../source/index/bintree/NodeBase
>         ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Root
>         ${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChain
>         ${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainBuilder
>         ${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainOverlapAction
>         ${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainSelectAction
>         ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/DoubleBits
>         ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/IntervalSize
>         ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Key
>         ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Node
>         ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/NodeBase
>         ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Root
>         ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Quadtree
>         ${CMAKE_SOURCE_DIR}/../../source/index/strtree/AbstractNode
>         ${CMAKE_SOURCE_DIR}/../../source/index/strtree/AbstractSTRtree
>         ${CMAKE_SOURCE_DIR}/../../source/index/strtree/Interval
>         ${CMAKE_SOURCE_DIR}/../../source/index/strtree/ItemBoundable
>         ${CMAKE_SOURCE_DIR}/../../source/index/strtree/SIRtree
>         ${CMAKE_SOURCE_DIR}/../../source/index/strtree/STRtree
>         ${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineEvent
>         ${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineIndex
>         ${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineInterval
>         ${CMAKE_SOURCE_DIR}/../../source/io/ByteOrderDataInStream
>         ${CMAKE_SOURCE_DIR}/../../source/io/ByteOrderValues
>         ${CMAKE_SOURCE_DIR}/../../source/io/ParseException
>         ${CMAKE_SOURCE_DIR}/../../source/io/StringTokenizer
>         ${CMAKE_SOURCE_DIR}/../../source/io/Unload
>         ${CMAKE_SOURCE_DIR}/../../source/io/WKBReader
>         ${CMAKE_SOURCE_DIR}/../../source/io/WKBWriter
>         ${CMAKE_SOURCE_DIR}/../../source/io/WKTReader
>         ${CMAKE_SOURCE_DIR}/../../source/io/WKTWriter
>         ${CMAKE_SOURCE_DIR}/../../source/io/Writer
>         ${CMAKE_SOURCE_DIR}/../../source/noding/IntersectionAdder
>         ${CMAKE_SOURCE_DIR}/../../source/noding/IntersectionFinderAdder
>         ${CMAKE_SOURCE_DIR}/../../source/noding/IteratedNoder
>         ${CMAKE_SOURCE_DIR}/../../source/noding/MCIndexNoder
>         ${CMAKE_SOURCE_DIR}/../../source/noding/NodingValidator
>         ${CMAKE_SOURCE_DIR}/../../source/noding/Octant
>         ${CMAKE_SOURCE_DIR}/../../source/noding/ScaledNoder
>         ${CMAKE_SOURCE_DIR}/../../source/noding/SegmentNode
>         ${CMAKE_SOURCE_DIR}/../../source/noding/SegmentNodeList
>         ${CMAKE_SOURCE_DIR}/../../source/noding/SegmentString
>         ${CMAKE_SOURCE_DIR}/../../source/noding/SimpleNoder
>         ${CMAKE_SOURCE_DIR}/../../source/noding/snapround/HotPixel
>         ${CMAKE_SOURCE_DIR}/../../source/noding/snapround/MCIndexPointSnapper
>         ${CMAKE_SOURCE_DIR}/../../source/noding/snapround/MCIndexSnapRounder
>         ${CMAKE_SOURCE_DIR}/../../source/noding/snapround/SimpleSnapRounder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferBuilder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferOp
>         ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferSubgraph
>         ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/OffsetCurveBuilder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/OffsetCurveSetBuilder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/RightmostEdgeFinder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/SubgraphDepthLocater
>         ${CMAKE_SOURCE_DIR}/../../source/operation/distance/ConnectedElementLocationFilter
>         ${CMAKE_SOURCE_DIR}/../../source/operation/distance/ConnectedElementPointFilter
>         ${CMAKE_SOURCE_DIR}/../../source/operation/distance/DistanceOp
>         ${CMAKE_SOURCE_DIR}/../../source/operation/distance/GeometryLocation
>         ${CMAKE_SOURCE_DIR}/../../source/operation/GeometryGraphOperation
>         ${CMAKE_SOURCE_DIR}/../../source/operation/IsSimpleOp
>         ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/EdgeString
>         ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeDirectedEdge
>         ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeEdge
>         ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeGraph
>         ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMerger
>         ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineSequencer
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/EdgeSetNoder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/ElevationMatrix
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/ElevationMatrixCell
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/LineBuilder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/MaximalEdgeRing
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/MinimalEdgeRing
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/OverlayNodeFactory
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/OverlayOp
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/PointBuilder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/PolygonBuilder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeDirectedEdge
>         ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeEdge
>         ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/EdgeRing
>         ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeGraph
>         ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/Polygonizer
>         ${CMAKE_SOURCE_DIR}/../../source/operation/predicate/RectangleContains
>         ${CMAKE_SOURCE_DIR}/../../source/operation/predicate/RectangleIntersects
>         ${CMAKE_SOURCE_DIR}/../../source/operation/predicate/SegmentIntersectionTester
>         ${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBuilder
>         ${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBundle
>         ${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBundleStar
>         ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateComputer
>         ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNode
>         ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNodeFactory
>         ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNodeGraph
>         ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateOp
>         ${CMAKE_SOURCE_DIR}/../../source/operation/valid/ConnectedInteriorTester
>         ${CMAKE_SOURCE_DIR}/../../source/operation/valid/ConsistentAreaTester
>         ${CMAKE_SOURCE_DIR}/../../source/operation/valid/IsValidOp
>         ${CMAKE_SOURCE_DIR}/../../source/operation/valid/QuadtreeNestedRingTester
>         ${CMAKE_SOURCE_DIR}/../../source/operation/valid/RepeatedPointTester
>         ${CMAKE_SOURCE_DIR}/../../source/operation/valid/SimpleNestedRingTester
>         ${CMAKE_SOURCE_DIR}/../../source/operation/valid/SweeplineNestedRingTester
>         ${CMAKE_SOURCE_DIR}/../../source/operation/valid/TopologyValidationError
>         ${CMAKE_SOURCE_DIR}/../../source/planargraph/DirectedEdge
>         ${CMAKE_SOURCE_DIR}/../../source/planargraph/DirectedEdgeStar
>         ${CMAKE_SOURCE_DIR}/../../source/planargraph/Edge
>         ${CMAKE_SOURCE_DIR}/../../source/planargraph/Node
>         ${CMAKE_SOURCE_DIR}/../../source/planargraph/NodeMap
>         ${CMAKE_SOURCE_DIR}/../../source/planargraph/PlanarGraph
>         ${CMAKE_SOURCE_DIR}/../../source/planargraph/Subgraph
>         ${CMAKE_SOURCE_DIR}/../../source/planargraph/algorithm/ConnectedSubgraphFinder
>         ${CMAKE_SOURCE_DIR}/../../source/precision/CommonBits
>         ${CMAKE_SOURCE_DIR}/../../source/precision/CommonBitsOp
>         ${CMAKE_SOURCE_DIR}/../../source/precision/CommonBitsRemover
>         ${CMAKE_SOURCE_DIR}/../../source/precision/EnhancedPrecisionOp
>         ${CMAKE_SOURCE_DIR}/../../source/precision/GeometrySnapper
>         ${CMAKE_SOURCE_DIR}/../../source/precision/LineStringSnapper
>         ${CMAKE_SOURCE_DIR}/../../source/precision/SimpleGeometryPrecisionReducer
>         ${CMAKE_SOURCE_DIR}/../../source/simplify/DouglasPeuckerLineSimplifier
>         ${CMAKE_SOURCE_DIR}/../../source/simplify/DouglasPeuckerSimplifier
>         ${CMAKE_SOURCE_DIR}/../../source/simplify/LineSegmentIndex
>         ${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineSegment
>         ${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLinesSimplifier
>         ${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineString
>         ${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineStringSimplifier
>         ${CMAKE_SOURCE_DIR}/../../source/simplify/TopologyPreservingSimplifier
>         ${CMAKE_SOURCE_DIR}/../../source/util/Assert
> #       ${CMAKE_SOURCE_DIR}/../../source/util/AssertionFailedException
>         ${CMAKE_SOURCE_DIR}/../../source/util/GeometricShapeFactory
> #       ${CMAKE_SOURCE_DIR}/../../source/util/IllegalArgumentException
>         ${CMAKE_SOURCE_DIR}/../../source/util/math
>         ${CMAKE_SOURCE_DIR}/../../source/util/Profiler
> ${CMAKE_SOURCE_DIR}/../../source/util/UnsupportedOperationException
> ADD_LIBRARY(geos SHARED ${GEOS_SRCS})
> ADD_LIBRARY(geos_i STATIC ${GEOS_SRCS})
> ADD_EXECUTABLE(TestSweepLineSpeed
> ${CMAKE_SOURCE_DIR}/../../tests/bigtest/GeometryTestFactory
> ${CMAKE_SOURCE_DIR}/../../tests/bigtest/TestSweepLineSpeed)
> TARGET_LINK_LIBRARIES(TestSweepLineSpeed geos)
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20060904/3552e7f5/attachment.html
